Oil pump o-ring has me scared!
Old Oct 10, 2008 | 10:43 AM
MattZ28's Avatar
MattZ28
Default Oil pump o-ring has me scared!
So I'm doing my cam swap next Friday, and all this stuff I'm reading about the oil pump o-ring has got me pretty worried.
What I've gathered:
-Pick up two BLUE oil pump o-rings, just in case one gets pinched
-Keep a clean rag under the oil pump pickup, JUST IN CASE the bolt gets dropped.
-Practice reinstalling with the OLD o-ring in place first.
-Leave the oil pump unbolted when attaching the pickup tube, with the O-ring and tube well-lubed with motor oil
-The pickup tube should "snap" into place and be fully seated before being bolted in, otherwise the o-ring will get pinched
-Once it is seated and bolted in, bolt the oil pump in place.
Does this sound accurate? Any other tips anyone else can contribute?
Old Oct 10, 2008 | 11:05 AM
B-Vette's Avatar
B-Vette
You could use some Dow Corning 111 grease or a similar product to hold the o-ring in place so that it doesn't get pinched.
Old Oct 10, 2008 | 11:22 AM
bfhawki's Avatar
bfhawki
St. Jude Donor '06
Put the well lubed o-ring over the pickup tube first and then slide pickup tube into oil pump. Do not put the o-ring in the pump first and then slide onto pickup tube. That is how most o-rings get cut.
Old Oct 10, 2008 | 11:55 AM
keliente's Avatar
keliente
My tip is not to panic! Don't overanalyze this and you will be fine
Old Oct 10, 2008 | 12:05 PM
Internets_Ninja's Avatar
Internets_Ninja
you could try some sex wax on the O-ring so that it has a less likely chance at ripping when you start sliding it down on the shaft.
Old Oct 10, 2008 | 12:36 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
I agree with the other folks here. It’s not that big of a deal. Lube it up, slide it on the tube, once on, make sure it’s not twisted or nicked, and install the tube into the pump. As far as lubes, I personally would use nothing but the same type of oil I plan to run in the engine. Using thicker lubes of unknown properties adds a risk factor of contaminating your engine oil with something that could hurt the engine now or later. Plain oil works fine.
Keep us posted on how things are going. I’m sure you will do fine.
Regards,
Eric D
Old Oct 10, 2008 | 01:02 PM
vettenuts's Avatar
vettenuts
Practice with the old one. Make sure the tube is centered and it will slide in with a little push. If you have to force it then its wrong. I use Redline Assembly Lube, stays in place and lubricates much better. I also clean the tube and put it on the tube dry so it stick to the tube.
Old Oct 10, 2008 | 04:29 PM
fst85vtt's Avatar
fst85vtt
Treat it like the ***** that it is!!!! Lube it up
and Stick it in!!!!
Old Oct 10, 2008 | 04:34 PM
dmiz0420's Avatar
dmiz0420
:wit hstupid:
Ask me how I know.....
You will not have a problem if you follow this advice.
Old Oct 10, 2008 | 07:08 PM
double-oh-coupe's Avatar
double-oh-coupe
You'll be fine ... just follow all the great advice on The Forum and you'll be fine. I've done it, and I never practiced -- I just followed the how-to's and got it done.
Old Oct 10, 2008 | 08:27 PM
02gt350's Avatar
02gt350
its over played. put on the ring then pop the tube on....
Old Oct 10, 2008 | 09:03 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The job isnt all that difficult and like many have already stated, lube it up, slide it on the pick up tube and gently push it in to the pump. If your really concerned, once the tube is fully seated in the pump, use a small inspection mirror and look at the flange and see if you see any of the O ring. If you dont, your golden. If you do, its pinched. I had my oil pump out 5 times and never once had an issue with the O ring.
keliente
My tip is not to panic! Don't overanalyze this and you will be fine..
BC
Old Oct 10, 2008 | 09:10 PM
MattZ28's Avatar
MattZ28
Thanks guys! Just trying to cover my bases. The less hang-ups, the quicker I'll get this done and the less headaches I'll have.
Old Oct 10, 2008 | 09:41 PM
Internets_Ninja
until i hit you
To Oil pump o-ring has me scared!
