Halltech Venom + CEL
Old Oct 26, 2008 | 05:44 PM
ZShot's Avatar
ZShot
Default Halltech Venom + CEL
Installed my Venom the night before last. Since then I have put about 100 miles on the car with no problems.
This afternoon, I washed my car and afterwards, drove it to get something to eat. On my way back home, the check engine light came on. I popped the hood in my garage to make sure nothing came loose, etc. I then inspected the air filter and noticed if had gotten a little bit damp, as a result of the washing.
Think this could throw on the CEL and what's the best recourse? Dry off the filter with a blow dryer?
Otherwise, no issues with the Venom. The install was straight forward. It would be nice it the kit came with instructions though. Fitment was perfect.
Old Oct 27, 2008 | 09:39 AM
Dave68's Avatar
Dave68
My guess is that the check engine light has nothing to do with the Venom install. Grab the code and let us know what it is. It coould be the smog pump check valve that sits behind the intake manifold. My check valve threw the check engine light a few weeks ago. I reset it and it's been fine ever since.
Another thing to consider is that 02-04 Z06s do not have MAF screens. The turbulent flow of air past the heated wire increases in velocity after an aftermarket filter system is installed, potentially causing a lean code to be thrown. This was an issue with Halltech Stinger - equipped Z06s. Some owners had their cars dyno-tuned. Others installed screened MAFs. If you are seeing a lean code, contact Jim Hall of Halltech. He should have some answers for you.
Old Oct 27, 2008 | 11:34 AM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
It could be related if it is a lean code. Here is what would be causing that condition, and it is easy to fix.
Our connector hose is thicker than the plastic MAF end and when the hose-clamp is connected to the hose, if it is touching the plastic alignment tab on the MAF, it is not sealing the hose to the MAF.
The easy fix is to use the stock slotted hose clamp as shown here in the Supplemental Installation Instructions:
http://www.corvettels7.com/c5supplementalinstall.pdf
This should take care of the problem. You can clear the codes on your DIC. Be sure they are not related to other issues that you need to have the dealer look at first.
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
423-915-6056
For service email:
orders@halltechsystems.com
www.halltechsystems.com
Old Oct 27, 2008 | 06:01 PM
ZShot's Avatar
ZShot
Wish I would've read these last night.
I blow dried the air filter and reset the ECU (which cleared any possible codes). I'm not sure what was causing the CEL originally.
After driving it 60 miles today, no issues and no CEL's to report.
Old Oct 27, 2008 | 06:25 PM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
The only time we see this pop up is when the hose clamp is not clamping on the hose due to the tab interference.
Jim
Old Oct 27, 2008 | 11:27 PM
Dave68's Avatar
Dave68
If it IS a lean code, it will come back after a number of starts. I'd follow Jim's advice and check the clamp, ASAP!
Old Oct 28, 2008 | 11:33 AM
ZShot's Avatar
ZShot
I'll double check, but last I looked, the notch was seated with the clamp.
Old Oct 28, 2008 | 12:39 PM
ZShot's Avatar
ZShot
Okay, I think I see what the issue may be. The way the elbow sits, it pulls the bottom of the clamp upward, causing it to work its way free a bit. Any ideas of a solution? I just reset it, but I believe it will continue to do this. Maybe i can fix by angling the connection to the TB upwards some?
Old Oct 28, 2008 | 03:16 PM
Dave68's Avatar
Dave68
The clamps should be tight enough so that the "tubes" (TB coupler and airbridge) cannot rotate, but not any tighter. Overtightening can distort the platic or rubber parts and cause the clamp to walk and the plastic/rubber parts to lose their sealing ability. I'm not sure what it is that you call an elbow, but my Stinger connections stay tight until I take things apart to clean the filter (every 5000 miles or so).
Old Oct 28, 2008 | 03:26 PM
ZShot's Avatar
ZShot
Didn't know the exact name of the part, but I do now... I did ensure it isn't overtightened. So far it seems to be holding good since I readjusted.
Old Oct 28, 2008 | 11:27 PM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
Looks good to me. I think you have the problem solved.
Jim
Old Oct 29, 2008 | 02:31 AM
ZShot's Avatar
ZShot
Jim
Gracias.
So far I'm real happy with the aesthetics of the kit and the install was fairly easy. Toughest part was removing the stock kit.
Old Oct 31, 2008 | 10:54 AM
ZShot's Avatar
ZShot
Default CEL Came back on
Okay, the check engine lamp came back on this morning. These are the codes I pulled from it.
P0171 H Fuel Trim System Lean bank 1-B
P0174 H Fuel Trim System Lean bank 2-B
I rechecked the connections for the intake and they are snug and the tab is still aligned.
Any suggestions?
Old Oct 31, 2008 | 11:05 AM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
P0171 Fuel Trim System Lean bank 1-B
P0174 Fuel Trim System Lean bank 2-B
Any suggestions?
The C6 MAF is the fix. GM decided to change the 02-04 Z06 MAFs by pulling out the laminar flow honeycomb screen. That screen keeps the fuel trims steady.
We have one in stock we can swap out for your MAF. I guarantee this will end the issue.
You can also program the MAF trims mostly at idle to dial in the Long Term Trims, but this swap has worked in every case we have run into.
Interestingly, this only occurs once a year, out of hundreds of units sold. I think some of the MAFs read on the high side to begin with +fuel, and when coupled with any aftermarket intake that lowers restriction, they go beyond the threshold of positive trims causing the lean codes. There are many other things, such as vacuum line leaks that can cause this code, but if you did not ever see it before, it is likely the new intake, or the installation.
I once had a customer with an LS1 have this issue back in 2001. He came by our shop, then in HB CA and it turned out that he had a vacuum line to open cutouts in his exhaust. That line had a cut in it near the hose clamps and was leaking. That small amount of extra air, caused the codes.
email me at inquiry@halltechsystems.com
Old Oct 31, 2008 | 11:36 AM
intoc6s's Avatar
intoc6s
Very interesting thread! Im gonna make sure that my clamp is lined up correctly, as i have a Halltech too and i never noticed the clamp looking like that with a notch in it.
Old Oct 31, 2008 | 12:11 PM
ZShot's Avatar
ZShot
Thank you very much for your help with this issue.
Old Nov 8, 2008 | 09:31 PM
ZShot's Avatar
ZShot
I received the new C6 MAF from Halltech a couple days ago and installed it last night. Went in without a hitch and I am extremely satisfied with the entire process.
Jim is a very stand-up guy. He was under no obligation to go thru the hoops he did. It really shows the level of customer service which is provided by Halltech.
to Jim and Halltech.
Thanks again.
Old Nov 8, 2008 | 10:13 PM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
*Install Instructions
To Halltech Venom + CEL
