Intake...? Blackwing or Vararam
Old Nov 22, 2008 | 11:40 PM
LT1vette's Avatar
LT1vette
Default Intake...? Blackwing or Vararam
How do these itakes compare? Which one shows the best power increase, the Black or the Vararam?
Are these considered to be two of the top intakes or are there better ones out there?
THX
Old Nov 22, 2008 | 11:44 PM
Dave68's Avatar
Dave68
My costs may be a bit off, but most of what is stated here is based upon my experience with aftermarket intake systems for the C5....
If you live in California, think twice about the Vararam, as it can be a royal pain to install/uninstall/reinstall for smog tests. If you live in a state that doesn't have visual inspections, then also take a look at the following (grouped by cold air and non-cold air, but in no particular order) and my comments, if any:
Vararam: Brings cold air in through the fog light panel area to a panel-type filter. Owners have had good luck with system on the dragstrip, but plan on spending hours to install and a bit more to get everything lined up well. Downside: Eliminates engine bay-cooling air that would've come in from the fog light panels (Z06 or coupe/vert with opened-up panels), so the engine bay may end up being toastier, especially if you add headers later. $300-$400 (NOT smog legal in CA)
Vortech Rammer: Brings cold air up from in front of the radiator and into an enclosed box. Its filter is quite a bit smaller than the Halltech Warhead or Blackwing unit. $250 (NOT smog legal in CA)
Callaway Honker intake system: This one relocates the MAF so that it is just in front of the throttlebody. It directs cold air from underneath and costs about $500. I believe this unit is 50 states legal (smogwise) for non=Z06 C5s. Excellent design and quality. If cost is no object, this bad boy should be at the top of your list.
K&N FIPK: This is more of a semi-cold air system, as the cold air intake opening is more of a slit. Its filter endcaps are carbon fiber. However, it is configured similarly to the Halltech Stinger-R and is 50-states legal. $350
Reverse Zip-tie: Allows cold air to be drawn in from underneath, but the bare filter is exposed to potential damage from larger objects. The advantage here is that you may pass smog if the tech doesn't know "which way is up".
Warm air systems: (Easy installation)
Halltech Stinger-R: Not only contains the massive Warhead filter, but also includes a larger-than-stock airbridge and smooth throttlebody coupler. For $350.00 or less, this system represents one of the best bangs for the buck. Fortunately, if you don't like Z06 screens in front of cored-out fog light panels, (for about $40) you can add cold air induction. See my procedure at http://www.conceptualpolymer.com/corvette_c5_corner.htm
This is what I did and a swap to smog-legal status is very easy to do, as I have kept my Z06 intake box.
Halltech Stinger SSM: This intake system features an even larger filter than that of the Stinger-R, TRAP, and Blackwing. < $400
Blackwing: Includes just a large filter, but an excellent one at that. Its cost is close to that of the Stinger. Like the Stinger, it is not smog-legal in CA, but can easily be swapped.
Volant Twin Cone: This system gives you more open filter surface area than any stock box does and is well suited to an engine bay that gets cold air in from the fog light panels, as the filters are more or less in the air flow path. $265
2002+ Z06 airbox cover: A larger opening allows more air to be drawn in through the filter. Expect up to a 5 RWHP gain from this simple swap. $50
Zip-tie: An easy and inexpensive mod (eliminates the OEM box’s upper lid), but its sealing ability is questionable at best.
According to Jim Hall of Halltech, at 95-degrees IAT, the Blackwing (and other non-CAI intakes) will lose 1 degree of timing. At 135-degrees a full 12 degrees is pulled on the LS1 which equals 10 RWHP.
I measured before and after air intake temperature data with a stock Halltech Stinger and then with the same intake but with my CAI mod. The difference was staggering:
After sitting in traffic/slow-moving for 10 minutes or so, my stock Halltech setup was pulling in air that reached 145+ degreesF. Even after driving at highway speeds for 15 minutes, the intake temps never fell below 110F or so.
After installing my CAI mod, sitting in traffic/slow-moving for 10 minutes or more never produced more than 104 degrees F intake temps. After driving on the highway for less than a few minutes, the intake temps went all the way down to ambient temperatures (about 80 degrees F).
As far as horsepower gains, most aftermarket intakes will produce about the same horsepower gains if the intake air is kept relatively cool. During the many dyno runs I have seen, each car had its hood open and a large fan blowing air on the radiator. Vararam-equipped C5s produced the same gains as the Halltech and Blackwing-equipped C5s.
As was mentioned, the gains are only achieved permanently if the intake air is kept below a certain level. If not, much, if not all of your gains will be "dialed back" by the ECU.
Ebay specials: Most intake system air "runners" are made of plastic, not because it is the cheapest (it often isn't) material, but because the last thing most people want is the engine bay heat being transferred to the intake air via a metal runner. Many of the inexpensive Ebay intakes I've seen have metal runners - not good, IMO. Also, the filter is the most critical part of the intake system - why buy an unknown brand of filter for such a critical application? Please, don't cheap-out on an intake system. Stick with brands that have a long history of making quality products.
How good are these systems? My experience has shown that most will bump up RWHP by at least 10. The advantage of having cold air is that power will not be "dialed down" under slow moving/stop&go conditions.
You could easily lose 10 HP with a warm air system after engine bay temps rise during slow-moving conditions. Cold air prevents this from happening.
Old Nov 23, 2008 | 12:32 AM
sami85L98's Avatar
sami85L98
I have a vararam but if i do it again i would go with callaway without second thought. I know its almost $500 but with vararam most does upgrade Air bridge too thats another $150 so 150+300 = 450.
If u want i can sell WCC Air bridge (plain black) and Vararam, both have only $1000 miles on it for $375 shipped to ur door. Nothing wrong with it, infact the best breathing intake, i just like quality and look of callaway.
Old Nov 23, 2008 | 01:08 AM
happa's Avatar
happa
I had a black wing and I liked it, but I always heard Vararam was better on higher speeds.
Old Nov 23, 2008 | 02:56 AM
Bluefire's Avatar
Bluefire
My only experience is with VaraRam. It took ~3 hours to install. There was an immediate increase of hp felt on the "azz dyno". The car pulled a lot harder from 50 - 90+mph. It sounds like it sucks more air too.
I highly recommend it.
Old Nov 23, 2008 | 08:11 AM
rws.1's Avatar
rws.1
My wife has the black wing on her '04, I have a Vararam on my '01.
She drives both cars.....
She says she has been a good girl all year and wants a VaraRam for Xmas... nuff said.....
Old Nov 23, 2008 | 09:56 AM
jrose7004's Avatar
jrose7004
I've had a Blackwing for a couple of years but never had the other.
Old Nov 23, 2008 | 11:55 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
go with the black wing
When Vararam redesigns there products they stop making the filters for the prevous model and you have to pay $100 to upgrade
Old Nov 23, 2008 | 10:17 PM
warren s's Avatar
warren s
The Vararam is all about ET & MPH at the track. You can read all the reviews and listen to all the horror stories about bad quaility, but the fact is Vararam is selling ET. The new version is made way better and seals much better the the older model.
Instead of reviews and BS dyno numbers, all you have to do is go to the track and watch other Corvettes. If a best timeslip is not your goal - they are all pretty much the same.
It took me 90 minutes to install my Vararam. (Newer model)
Old Nov 23, 2008 | 10:18 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Yawn
Old Nov 23, 2008 | 11:47 PM
LT1vette's Avatar
LT1vette
Default Good info......
TTT for the night crew
Old Nov 24, 2008 | 08:42 AM
Blow Torch's Avatar
Blow Torch
I've had both on both of my C5s. Blackwing is a good intake, but as Dave indicated in his writeup, cool air makes HP. (and the warmer engine bay air loses it) There is NO ONE that is "in tune" with his car that will not be able to feel the different between the two intakes (ecspecailly on one of these 40 degree fall mornings)
I bought both of my vararams used for around $200. Both took around 2- 2 1/2 hrs to install. (And I have front spoilers on both cars)
I personally like the vararam
Old Nov 24, 2008 | 09:26 AM
ROJO99's Avatar
ROJO99
Have had both, and currently have the Vararam and prefer it when the two are compared.
Old Nov 24, 2008 | 11:24 AM
Gideon's_Test's Avatar
Gideon's_Test
I did the "flip tie" on my FRC..I dynoed 327whp on a Mustang dyno..Haven't figured out what else has been done to the vette, and didn't get a baseline, but I'm pretty happy with the "flip tie". Yeah, the air filter element (K&N) is sort of exposed, but not really as it sits on the upper inclined part of the shroud...It's cheap (<$50) , effective and looks stock..
Old Nov 24, 2008 | 12:41 PM
YO-EL's Avatar
YO-EL
There is no comparison...
You want more power? mORE mpg, qUICKER et AT THE TRACK..
iT ALL POINTS TO VARARAM..
Old Nov 24, 2008 | 08:43 PM
Nick1's Avatar
Nick1
My Sweetie and I both have almost identical 04's. She has the Blackwing and I have the Vararam. At the track this summer I ran 12.9 @ 107 and she ran 13.1 @ 106. So, the results I think are quite close.
The install on the Vararam is a pain but overall not too bad. The Blackwing is very easy.
For comparison sake, prior to the Vararam, I ran 13.2 @ 108, so I guess there was a measurable et gain.
All in all, if I had to do it over again, I might have gone for the simpler Blackwing or some equivelant.
Old Nov 24, 2008 | 11:36 PM
yaknow's Avatar
yaknow
Vararam sucks, tell me anyone who doesn't like it
To Intake...? Blackwing or Vararam
Old Nov 24, 2008 | 11:44 PM
jrose7004's Avatar
jrose7004
Just get a Blackwing and be done with it!
Old Nov 25, 2008 | 04:05 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
v a r a r a m !!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Nov 25, 2008 | 04:34 PM
DIXZ's Avatar
DIXZ
I have had both, if you're interested I'll sell you my Blackwing!
