mirror problem
Old Nov 26, 2008 | 04:01 PM
oldcorvetteguy's Avatar
oldcorvetteguy
Default mirror problem
anybody have any info on outside rear-view mirrors that come apart ? The keeper on the inside of my passenger mirror came off, and the dealer says there's no fix, must replace. The keeper's a 10cent item but it appears to be impossible to compress the huge spring inside the mirror without completely destroying it. Naturally the dealer wants about $300 for a new one, plus it has to be painted to match.By the way it's on a 98 coupe if it makes any difference. Any great ideas? I could always just glue it solid, right?
Thanks guys!
Old Nov 26, 2008 | 04:06 PM
byronhunter's Avatar
byronhunter
There is a repair for it, do a search!
http://97vette.com/howto/mirror/index.html
Old Nov 26, 2008 | 04:17 PM
Gideon's_Test's Avatar
Gideon's_Test
Old Nov 26, 2008 | 04:40 PM
oldcorvetteguy
Thanks everyone for the heads up!
Old Nov 26, 2008 | 06:59 PM
Bakersfield's Avatar
Bakersfield
I had the keeper come off a second time on the same mirror so before putting it back on, I drilled a small hole through the shaft. Once the keeper was pressed all the way down on the shaft, I managed to push some safety wire through the holes to keep the keeper from sliding off again. It was tedious, but worth the effort.
Old Nov 26, 2008 | 07:10 PM
oldcorvetteguy
Great idea. Now for the fun part!
Thanks!
CD
Old Nov 26, 2008 | 08:44 PM
4DRUSH's Avatar
4DRUSH
Instead of using a bolt,nut & washers to compress the spring. I used a 12" piece of all tread and drilled a 1/8" hole through it about one thread in from the end. Then I cut a piece of 3/4" copper water pipe about 1/2" long? Insert the all thread through the mirror,pin,spring and retaining clip, next put the copper pipe on top of the clip (which will act as a spacer) then slide the 1/8" drill bit in the hole you drilled. Put a nut/ washer on the other end of the all thread and tighten the nut till the ring snaps in place. ( I made the factory groove in the pin deeper with a hand held hack saw blade) I like the idea posted above about a pin added above the snap washer.
If you need any more info let me know.
Old Nov 29, 2008 | 11:47 PM
Jacks02's Avatar
Jacks02
Another reason why this forum is so valuable!! Bravo!!
To mirror problem
