Harlan sharp 1.7rr failure
Old Dec 2, 2008 | 05:42 AM
vettenuts's Avatar
vettenuts
Originally Posted by 427CPE
I'll let you guys know how I like the Yella Terras. Also have a backup Harlan Sharp coming in thanks to the warranty offered by HS.
The YT instructions aren't very good, set the wipe first then measure for pushrod length. The instructions cover several of their rockers and give the false indication that pushrod length determines the wipe pattern, which it doesn't for these rockers.
Old Dec 2, 2008 | 11:13 AM
427CPE's Avatar
427CPE
Does this kit come with shims?
I plan to:
-Mark the tip of the valve tip w/marker.
-Set the valve to zero lash and tighten, making sure I get the preload I want using adj pushrod.
-If preload is good, roll the engine over. RR should start on the top side of the valve tip and by mid lift be centered.
Old Dec 2, 2008 | 02:07 PM
vettenuts's Avatar
vettenuts
It comes with one set of shims.
