Head swap question...
Old Dec 1, 2008 | 08:22 AM
ROJO99's Avatar
ROJO99
Default Head swap question...
Does the water pump really need removed for a Head swap? Read a how-to over the weekend and they said to remove the WP.
Old Dec 1, 2008 | 09:40 AM
MattB's Avatar
MattB
Removing the water pump makes removing the Power Steering bracket a lot easier. It will most likely save you time.
Old Dec 1, 2008 | 09:47 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
I have a nice set of different length wrenches. I have no trouble removing the alternator bracket and have tons of practice. No need to remove the water pump unless you want to drain the block that way so you don't get water in your cylinders. I take the water pump off and put a shop vac on the block to suck out the coolant. It makes it much cleaner when you remove the heads. It's only 6-10mm bolts to yank off the water pump and the gaskets are reusable.
Old Dec 1, 2008 | 11:55 AM
vettenuts's Avatar
vettenuts
As previously stated, the time saved not removing the pump will be more than made up for with the mess you will have pulling the heads full of coolant.
Old Dec 4, 2008 | 03:51 PM
ROJO99's Avatar
ROJO99
Next question. Can the Power Steering Pump and bracket be un-bolted then pushed forward? The article I read was a HC write-up this is why I am asking. I am only doing Heads.
Old Dec 4, 2008 | 04:02 PM
zeevette's Avatar
zeevette
I would say, yes. It's really difficult to get to one of the bracket bolts, because of pulley interference, so it's much easier to remove the WP first, and the whole PS res, etc, should be able to cable tie up forward.
Old Dec 4, 2008 | 04:16 PM
BLOWNBLUEZ06
No reason to do more than unbolt it. For me, this is where a combination of long, medium and stubby wrenches comes in real handy.
Old Dec 4, 2008 | 05:04 PM
vettenuts's Avatar
vettenuts
Yes, with the water pump off the bracket will come off in a few minutes and you can set it forward. I tied it off with rope so it wasn't pulling in the PS lines.
Old Dec 4, 2008 | 05:20 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Yes.
Ratcheting box end or gear wrenches are your friend for this task. You won't be able to completely remove some of the bolts, as the PS reservoir and pulley will keep them captive in the bracket. But your goal is to merely unscrew them from the head and set the assembly aside.
Not a fun task reinstalling the assembly either, getting it lined up to get that first bolt started can be a real PITA by yourself. But I've done it twice, so it definitely can be done.
Old Dec 4, 2008 | 05:46 PM
VIPERBLUELX's Avatar
VIPERBLUELX
I didn't remove the waterpump when I did my head swap, didn't even think about it actually. The hardest thing for me was getting the power steering hoses broke loose from the rack. Come to think of it I can't really remember why or if those hoses even needed to be unhooked.
Old Dec 4, 2008 | 05:50 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
They don't.
They do for a cam swap obviously, since the rack needs to be removed..but no need to touch those lines for just a head swap.
Old Dec 7, 2008 | 01:20 PM
Uncle John's Avatar
Uncle John
Just did mine the other week. You don't have to remove the water pump. The "tough" bolt on the alternator bracket requires a shorter wrench than the standard length. 4 3/4 inches is perfect.
To Head swap question...
