Long Tubes and Emissions
Old Dec 10, 2008 | 07:06 PM
jjopalka's Avatar
jjopalka
Default Long Tubes and Emissions
What is it about Long Tube Headers that create a problem for Emissions.
Does it increase Emissions for some reason?
What am I missing?
Old Dec 10, 2008 | 07:25 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
What am I missing?
In most states, no problem at all. Even states that still sniff test, not a problem.
The problem is, the treehugger engineers (better known as CARB) know that catalytic converters work best when hot. The most heat available is exiting the exhaust ports of the engine...hence, the closer the cats are to the engine, the better they function, and the quicker they begin to function after startup..
Now, take that logic one step further, and create a "law", deeming any modification that relocates the cats further away from the engine heat as not allowed, because it makes them less effective and allows more pollutants into the air.
It's kind of impossible to use longer tube pipes without pushing the cats further downstream of the engine, so that there is why they are not and will never be , CARB-approved.
However, few if any other states (as of now) have such strict inspection and testing criteria, looking for that sort of thing. They might check fr the mere presence of cats, but aren't going to stress over their location, and/or being of an aftermarket (hi flow) variety.
Old Dec 10, 2008 | 07:41 PM
LoneStarFRC's Avatar
LoneStarFRC
What am I missing?
Not necessarily. It strictly depends on the .gov in your state as to what THEY think you should/should not be able to do to modify your car.
Old Dec 10, 2008 | 07:45 PM
LoneStarFRC
Much truth here but one thing to keep in mind: "CARB" is a California only creature. (California Air Resources Board) Unless a particular state has adopted the C.A.R.B. (California) standards, then "C.A.R.B." is meaningless.
HTH
Old Dec 10, 2008 | 07:59 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
HTH
Not really. Every single requirement CARB has come up with is federally adopted by the EPA.
Just because your state doesn't care or inspect for it, makes it no less illegal.
To put it in simpler terms, Long tube headers of any variety ARE federally prohibited, simply because CARB said so.
But realistically (and how most rationalize this), the chances of getting caught in the other 49 states is extremely slim. EPA has no real street-level enforcement presence, because the "laws" they strive to uphold aren't criminal, they're civil. They can't arrest you, they can only sue you for damages.
Old Dec 10, 2008 | 10:18 PM
LoneStarFRC
And yet they (long tube headers) are openly advertised and sold across the nation, yes?
So you're saying that the Feds (EPA) will (and HAVE) gone after someone like Casper's electronics for manufacturing and selling O2 simulators and yet leave all the long tube header manufacturers (which you say are also illegal in all 50 states) alone? Please explain.
Old Dec 11, 2008 | 01:11 PM
ysb02's Avatar
ysb02
http://www.epa.gov/compliance/resour...per-fcsht.html
"These devices were advertised for “off road use only” or “non-road use only.” However, the O2 Sims were designed and marketed to be used in regular production vehicles (“on road” or “on highway” vehicles), which is illegal under the Clean Air Act. In addition, while there are different control standards for “off road” vehicles (e.g., construction equipment) because of differences in the types of engines and applications, there is no general “off road” use exemption from the pollution control requirements of the Clean Air Act."
It's selective enforcement, the US Justice system is not fair nor will it be any time soon. Rather than just go after the people actually committing the crime (installing o2 sims on non-race cars) they just go after the maker knowing they won't be able to mount a good legal defense (takes $$$). Long tube headers could easily fit the description above.
Old Dec 11, 2008 | 02:31 PM
LoneStarFRC
I understand why Casper's position may have been untenable, but what I don't understand is that according to Y2K, the EPA has adopted a rule or regulation making anything C.A.R.B. requires an EPA requirement, which of course would mean the the State of California is the determiner of motor vehicle emission standards in this country, not any other state (unless it too adopts the C.A.R.B. standard). Further, according to what I have observed over the years, there are few, if any, disclaimers regarding long-tube headers being sold to or installed by, people in states OTHER than California.
I fully understand the nature of selective enforcement (time, resources, etc), but to simply ignore what (if true) is a LARGE scale and wide-spread violation of EPA laws across the country is not.
I have a strong suspicion that there may be more to this than just a case of C.A.R.B rule(s) being adopted by the EPA and therefore is the law in ALL 49 OTHER states.
If anyone has a specific link in the EPA rules/regs regarding their adoption (automatic or otherwise) of C.A.R.B. rules/regs, I would appreciate it.
Old Dec 11, 2008 | 03:19 PM
AU N EGL's Avatar
AU N EGL
and your tuner. LTs are not bolt on and go plus pass emissions.
A good tuner is needed.
A Good tuner, will make your vette run cleaner, and fewer emissions then in STOCK form.
Old Dec 11, 2008 | 03:30 PM
LoneStarFRC
I hear ya.
I'm just intrigued by this notion that because LT's are illegal in CA that they are also illegal in the remaining 49 OTHER states.
Old Dec 11, 2008 | 04:12 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
I hear ya.
Like I said, it's rarely enforced outside of CA, and because the other states don't care about them, everyone thinks it's legal.
In the EPA's eves, any non-stock cat, no cats, relocated cats....it's all the same difference to them, a violation.
I think you'lll agree running no cats whatsoever is considered illegal, but what you're not getting is that the very same law is also broken when replacing stock functioning cats, and/or moving them. Both of which is usually done with most LT systems.
If that doesn't make sense, then I could be equally as blind to say my huge-cammed catless car running zero 02 sensors and a splash of leaded race gas is also legal...because my car in fact does pass WI emissions testing like that with no problem.
Not getting caught, and being fully legal can be two very different things.
Old Dec 11, 2008 | 04:22 PM
ysb02's Avatar
ysb02
I don't think the EPA automatically adopts California rules. I *BELIEVE* they may adopt the CARB rules after looking at them and agreeing they should apply to the US in whole. You'd basically have one state setting federal law like you said which as far as I know doesn't happen.
California also has it's own local state EPA that is the parent org for CARB that's not the same as Federal EPA.
BTW In Austin I've never noticed them putting any of my vehicles on the lift nor checking underneath for exhaust issues. They do however pull computer codes but only certain codes with fail you. I had a truck throw a transmission temp code and the inspector said it was passable. Just the same I got cats on my ARH x-pipe.
Anyone know if Illinois is big on EPA enforcement? Noticed Casper's was there. Maybe a state official was looking for bribe
Old Dec 11, 2008 | 04:40 PM
LoneStarFRC
So you're saying that if someone has damaged cats and replaces them and also installs a LT system that does NOT change the specific mounting location then it's "legal"? And of course, to me at least, that begs the question what is "functioning"? What's the standard? Eye-of-the-beholder or driven by empirical data? Does that also mean that ANY cat other than an OEM unit is "illegal"? Does this mean that in addition to all LTs being illegal, that all non-OEM cats currently being manufactured and sold are also illegal?
Even I can figure that one out. Thanks.
Still interested in the C.A.R.B/EPA connection.
Old Dec 11, 2008 | 05:20 PM
bcartman2's Avatar
bcartman2
Who cares, our cars are a lot cleaner than many other cars on the road, and can be even cleaner after performace modifications when properly modified by a qualified tech.
Old Dec 11, 2008 | 05:21 PM
Aprilia1's Avatar
Aprilia1
States must submit emissions control strategies to meet Federal air quality standards for failure to attain/comply with the standards (existing or future) which are then approved/disapproved by the Feds. Control stategies including emissions control technologies and more restrictive tailpipe emissions limits are approved for that State however, they are not adopted as a Federal standard. That would be the tail wagging the dog and that isn't going to happen.
Other vehicle emissions requirements specific to hardware are shared by all and specifically are included in control equipment tampering laws. States other than Kali seem to take a more hands-off approach to enforcing a Federal law thus ECU codes and/or meeting tailpipe emission limits suffice. Obviously a bit more common sense based which counts Kali out! Would be willing to bet those days however will be over soon after January. Off-topic but just wanted to clarify...
A1
Old Dec 11, 2008 | 08:33 PM
LoneStarFRC
A1
Thanks for your input. That is essentially how I understood state rules vis-a-vis the EPA. I agree with the tail-wagging metaphor - not that the People's Republik wouldn't LOVE to be able to call the shots for the entire country.
Old Dec 11, 2008 | 08:55 PM
C5SCCA's Avatar
C5SCCA
I want to preface this statement by saying I have no factual evidence to back up any of this. However, I thought that C.A.R.B had a lawsuit pending against someone, maybe EPA, to try and gain control over air quality and stuff. Maybe that is what has already been said. Again, I am not stating fact. Until I can confirm this is just something I thought I had read.
Old Dec 13, 2008 | 10:12 PM
kcbeagle's Avatar
kcbeagle
You can pass emissions in WI with no Cats??
To Long Tubes and Emissions
