What battery is everyone using?
Old Dec 23, 2008 | 09:47 AM
C5MongooseTX's Avatar
C5MongooseTX
Default What battery is everyone using?
What car battery is everyone using these days?
"Edit" for now till I know if the problem is resolved.
Old Dec 23, 2008 | 12:11 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The place that you purchased Red Top. from should be able to warranty it if you have the purchase receipt! There shouldnt be ANY squabbling about the warranty. Try to find an Autoparts store that sells OPTIMA and bring the receipt and battery back to them.
If that falls through, go to WALMART and get a walmart battery. Cant beat them for the price. The last walmart battery I purchased lasted 6 years.
Old Dec 23, 2008 | 12:34 PM
berryj's Avatar
berryj
I use the Exide Orbital battery which is also a dry cell battery like the Optima. Mine works great and I use a Battery Tender jr to keep it juiced up with corvette downtime. I bought it at Napa auto.
Old Dec 23, 2008 | 12:57 PM
C5MongooseTX
Well, I guess I may need to retract my statement. I took the battery to have it checked out and it came out good. Seems my charger took a crap. So I bought a new AGM/Gel charger so we will see if this fixes the problem.
Old Dec 23, 2008 | 03:09 PM
jrose7004's Avatar
jrose7004
I had good luck with the Red Top I had in my 98, the 04 I have now has the Delco original equipment.
Old Dec 23, 2008 | 03:11 PM
4440stevesvette's Avatar
4440stevesvette
I got mine at NAPA. You can find a NAPA store in any small town in the entire country.
Old Dec 23, 2008 | 06:33 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
I've used Kirkland store brand batterys from Costco, for replacements in all my cars and trucks. Never had a problem of any kind with them, in more than 15 years of using them.
Old Dec 24, 2008 | 10:01 AM
jovette's Avatar
jovette
AC Delco replacement in October, 2005 by previous owner, in my now 9 year old, '00 Coupe.
Old Dec 24, 2008 | 10:53 AM
cwalsh's Avatar
cwalsh
Sears Diehard Platinum. I also have a battery tender now.
Chris
Old Dec 24, 2008 | 11:10 AM
Oldvetter's Avatar
Oldvetter
I use an Optima Red top, but I also use a battery maintainer when ever it sits for more than 3 days. These batteries do not like the slow current draw of a C5.
I would only use an AGM (Absorbant Glass Mat, they don't leak) battery. If battery leaks acid, your computer is under it, not worth the chance. People say new batteries don't leak, but better sure than sorry. I have used the Exide Orbital (an AGM Battery) with good results.
Old Dec 24, 2008 | 11:41 AM
DAV162's Avatar
DAV162
Sears Diehard
Old Dec 24, 2008 | 11:54 AM
hattitude's Avatar
hattitude
AC/Delco, professional series, 7 year battery (#86-7yr) .......
Old Dec 24, 2008 | 12:27 PM
Quicksilver Vert 01
Originally Posted by Oldvetter
I would only use an AGM (Acid Glass Mat, they don't leak) battery.
AGM stands for Absorbant Glass Mat.
The acid is fully absorbed into the woven glass matting that surrounds the plates, which makes the battery less likely to leak acid from the case.
Old Dec 24, 2008 | 12:29 PM
RedC5's Avatar
RedC5
Optima Red Top Battery burn date 12/2002, installed August 2003.....still strong in the cold Michigan weather. May be time to have another on hand just in case, 75/35.
Old Dec 24, 2008 | 02:30 PM
ROJO99's Avatar
ROJO99
Cheapo exide from the local parts store... Had a Red Top from Optima and had nothing but issues with the unit holding a charge for more than three weeks of inactivity.
Old Dec 24, 2008 | 03:13 PM
Brandon619's Avatar
Brandon619
I'm in the same boat right now with my red top.
Old Dec 24, 2008 | 03:18 PM
slothy's Avatar
slothy
orbital here 0 probs
To What battery is everyone using?
Old Dec 24, 2008 | 07:11 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Saw too many posts with bad Optima batteries, so on the '99 that I no longer have, the first AC Delco failed terribly with the positive post falling off which fortunately happened when I had the hood opened and looking at it. A Costco battery went in because that was the only place open at the time. Later, a Sam's battery went in when I detected a slightly slowing of the starter and here earlier this year before I gave away the car to my son, I put another new Sam's battery in it. Like Bill Curlee, they are cheap and they last.
Old Dec 24, 2008 | 08:57 PM
RedC5's Avatar
RedC5
Just ordered another 34/78 Optima about an hour ago....
Old Dec 24, 2008 | 11:54 PM
z06801's Avatar
z06801
Excide here too, they are on sale at at Checker for 70.00 bucks off just got one
