electric water pump
Old Jan 11, 2009 | 11:36 AM
KCvetteowner's Avatar
KCvetteowner
I don't want to hijack here, just wanted to list some other options:
If you do need to replace a water pump the LS3 water pump is a better option for LS1/LS6 owners. The only drawback is it does require you to also purchase a new tstat and tstat housing. The LS3 is 3-4 lbs lighter with less rotating mass. The large bell shaped pulley is replaced with a flattened model.
I recently saw Edelbrock makes a "high flow" water pump for LS1/2/6 motors but I don't know anything more about them...
Old Jan 11, 2009 | 10:09 PM
weinerschizel's Avatar
weinerschizel
No, LT1's have a camshaft driven water pump. They never had electric pumps from the factory. And I built my LT1 so when I did I put on an Electric Pump. It's been on for over 20k miles no problem what so ever.
The electric pump made a much bigger difference in power than I had thought it ever would. I was curious if the LS1 benefits equally well.
I suppose I'll just put on a stock pump. They're so much cheaper. I was really surprised, the LS1 electric pump was so ridiculously expensive. My LT1 pump was $150. The LS1 electric pump is $600 with the stock one around $150.
Old Jan 11, 2009 | 10:13 PM
weinerschizel
What is the difference in Tstats between the LS1 and LS3 pumps? Does it take a standard SBC tstat? I hate this LS1 tstat / housing it's really expensive as I have to purchase a 160 degree thermostat.
Old Jan 11, 2009 | 10:46 PM
KCvetteowner
The LS1 is the one piece design housing/tstat, and the LS3 is two piece. Not sure if it uses a standard tstat..
Just an fyi....the reason the LS1/LS6 water pumps have that large bell pulley is because it simplified belt positioning by using the same water pump for the Firebird, Camaro and GTO. Some of those engines used two belts side by side on the large pulley and some used a belt on the outer edge of the pulley.
Old Jul 13, 2009 | 06:33 AM
crosstheline's Avatar
crosstheline
bookmark
Old Jul 13, 2009 | 08:40 AM
allngn_c5's Avatar
allngn_c5
Originally Posted by LoneStarFRC
I would not recommend one for anyone on a DD or one that sees a lot of drive-time throughout the year. They are expensive and I don't trust the long-term reliability. The average belt driven pump goes for years and besides, other than the ability to operate it while the engine is off, what real benefit is it to the average street driven car? If it's hp, then there are other (more reliable) ways to gain hp that small.
3 years + with ZERO problems. I call that pretty reliable. Handled the hauls from Detroit to Dallas and Dallas to Detroit with ease. Helped my h/c 346 get 34 mpg actual and on my run from Atlanta to Detroit it kept my 541 rwhp 505 rwtq 402 cool and get 27 mpg.
An ewp frees up parasitic loss thus releasing bound HP, it doesn't actually create any. Seen many graphs showing as little as 3 rwhp 5 rwtq, to 10 rwhp 10 rwtq gains. I don't know for sure about the hp increase but I do know my gas mileage improved.
I would add an ewp and ud pully at the same time and call it the gas mileage combo. I adde about 4 1/2 mpg with the combo on my 346, and re used them on my 402. The 402 gets 27 mpg as long as I keep my foot out of it.
For those concerned about cooling capacity, I say don't worry. I did an extended 20+ mile drive in 85* temps on the highway and my speeds never dropped below 120. My coolant temps never got above 169. I'd say the EWP works. I even plan on reusing it if/when I go FI.
Old Jul 14, 2009 | 10:00 AM
weinerschizel
Yeah like I said the one on my LT1 was AWESOME... and it has been on there for 4 yrs w/ around 50k miles on it and no problems what so ever. However, it was like $150 new for a CSR pump. The LS1 was around $600.
Old Jul 14, 2009 | 10:57 AM
allngn_c5's Avatar
allngn_c5
I paid 569 or 589 3 years ago, and now I've seen them in the 639 range. Regardless of what people say I like mine. The extra gas mileage I've received has helped offset the cost of the pump as well. Just a quick estimate, probably saved 50 gallons of fuel over the course of 13,000 miles or so. Thats around 150-200 bucks when you factor in that gas was over 4.29 / gallon last summer for premium. A few more years and I break even. I love being able to go on really long trips and only have to stop for gas once vs two or more times. The ewp and ud pully are a big part of why I get such good gas mileage when using cruise control in 6th gear set at 70-80 mph.
Old Jul 14, 2009 | 12:24 PM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
Not to get sidetracked here, but isn't it far easier/cheaper to do the "wire under the relay" for keeping your fans on during an auto-x? Heck, you could even do a switch on that same thing and turn the fans on/off manually.
File Type: pdf
Old Jul 18, 2009 | 06:00 AM
intoc6s's Avatar
intoc6s
I used a Meziere Electric water pump on my LT1 and it worked flawlessly, and i now run one on this engine. My temps Never get to 200, even on hot days. I was running it pretty hard the other day and it still didn t get to 200(on the guage, anyway). I like the idea of the few HP and the small MPG gain. Its a chrome one but u really can t see it even when u try to look at it.... Im all for them, 2 of them and ZERO problems!
Old Jul 18, 2009 | 09:03 AM
vettenuts's Avatar
vettenuts
I understand it has worked well for you and you seem to have benefited from it, but when the pump does fail the car can't be driven. Do you plan preventative maintenance? I thought Meziere recommended a rebuild on a time/mileage basis?
Just wondering as this has always been something I would like to do but am fearful of getting stuck a long way from home.
Old Jul 18, 2009 | 12:04 PM
allngn_c5's Avatar
allngn_c5
I guess I am an optimist. I don't think about the EWP failing so it doesn't.... LOL.
Meziere may have a schedule or something, but if I knew what it was I have long forgotten it. Post it if you find one.
Old Jul 18, 2009 | 03:14 PM
  #33
GREG O.'s Avatar
GREG O.
I looked into it. Two issues I found were the Meziere pumps 55 GPM (open) which is less than stock at above approximately 5,000 RPM. So if you are pumping less, I was worried about cooling the rear cylinders. Secondly, they don't have a very good reliability for street driving from what I have seen and would worry about getting stuck out on the road.
I called Meziere to ask them about my elec. water pump... He said i had an early model. cost $720.00 street -- strip version AND it should be due for a rebuild. I liked to ****. Here is a Co. that basically builds water pumps for u to perform at the highest standards and I am due for a rebuild The pump only had about 10k on it. and the rebuild said cost $ 250.00 +shp. and handling. Well about 3 months and 12
hundred miles the sucker started dripping I have seen mechanical pumps for $125.00 on fleabay with a LIFETIME warranty. Anyway, i still have my pump. it was taken off last week. put on meck. pump. I probably lost 10HP but at least i won't have a garbage
Meziere pump. btw. it's for sale !!!! or trade !!!!
Old Jul 18, 2009 | 03:57 PM
  #34
allngn_c5's Avatar
allngn_c5
I am sorry to hear that you had issues. When you say early model, what year did you buy this pump? I got mine in 2006 and as stated flawless operation. I thinks its EWP147 or something, chose anodized RED. I might be interested in buying if from you and having it rebuilt so I have a back up in the car in case my current one were to go while on a trip. What year is your car? I want to be sure that it will work. M6 or a4??
Old Jul 18, 2009 | 06:07 PM
  #35
Fratbragen's Avatar
Fratbragen
I put a 55 GPM meziere on last year. No problems and not noisy. It does flow better below 3,000 RPM. I drive mine on weekends. I believe realistically I picked up 5-7 RWHP. I believe BMW has started manufacturing cars with electric WP's from the factory. No complaints thus far.
