Rubberized undercoating and heat?
Old Jan 9, 2009 | 09:52 AM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
Default Rubberized undercoating and heat?
I plan to take two stock tunnel plates, sandwich heat/noise barrier material in between them and spray the sandwich with rubberized undercoating. Once it dries well I will install.
I know that the fumes are flammable while drying and I plan do dry for about a week before installing the assembled piece. Will there be an issue with exhaust or drivetrain heat on the tunnel plate? Thanks
Cajun
Old Jan 9, 2009 | 10:27 AM
slothy's Avatar
slothy
anything on the can saying max temp? only spot i could see being a big problem is the cat area if you are running cats
Old Jan 9, 2009 | 10:32 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Cajun
I'd skip the rubberized coating.
Old Jan 9, 2009 | 10:33 AM
0Cajun @ Edgyvette
Former Vendor
Is there anything I can spray on it to add heat and noise dissapation? What about truck bed liner or something similiar?
Cajun
Old Jan 9, 2009 | 10:34 AM
AU N EGL's Avatar
AU N EGL
skip the rubbberized coating. Use the KoolMat products for insulation.
http://www.lgmotorsports.com/catalog...oducts_id=1565or
http://www.koolmat.com/corvette.shtml
Plus coated Long tube headers do quite a bit to keep heat out of the cabin.
slothy's Avatar
slothy
what about dropping them off at a local coater to get ceramic coated?
Old Jan 9, 2009 | 11:03 AM
0Cajun @ Edgyvette
Former Vendor
That might be an option. I am thinking of using the frost king insulation in between the two plates but will have to heat test that. Also might go with this
http://www.jcwhitney.com/COOL-IT-ADH...1115_10114.jcw
Old Jan 9, 2009 | 11:04 AM
0Cajun @ Edgyvette
Former Vendor
I am sure that stuff is off the hook but the prices are absolutely ridiculous. If I was going to pay that amount I would just buy a plate from a vendor. I am trying to be cheap here guys
Old Jan 9, 2009 | 11:29 AM
lucky131969's Avatar
lucky131969
Yeah, that's obvious....
Have you already used an insulation in the interior of the car (floor/tunnel)area? This would be more effective from a sound perspective, because the tunnel plate is open on both ends, so sound can still travel. For heat, you can just apply a high temp insulation on the top of the tunnel plate itself. I would not bother with the undercoating or two tunnel plates.
Old Jan 9, 2009 | 11:32 AM
0Cajun @ Edgyvette
Former Vendor
I will look into those options. I will have to do some testing. By the time I am done it will probably cost me more than just buying one, BUT then I would not get to play
Old Jan 9, 2009 | 11:59 AM
AU N EGL's Avatar
AU N EGL
then go to Lowes or HomeDepot and look at the water heater insulation wrap.
Old Jan 9, 2009 | 12:11 PM
0Cajun @ Edgyvette
Former Vendor
Word brother, thats what I am talking about. Good call
Old Jan 9, 2009 | 12:48 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Cajun
Just pony up the $$ and get a real tunnel plate and some heat shield to it.
You could also buy some b-quiet on ebay for cheap and install that on the floor boards inside the car.
It makes a big difference. I use to run a maggie with headers and stingers and it was nice and quiet in the car with these mods.
Old Jan 9, 2009 | 12:56 PM
hotwheels57's Avatar
hotwheels57
The 3M "rubberized" coating (aerosol can) is asphalt based...
Old Jan 9, 2009 | 01:08 PM
lucky131969
Which means it will most likely turn to goo at high temps, especially above the cats. Hot asphalt would not be a pleasant smell in the car.....
Old Jan 9, 2009 | 01:12 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
you smell like a roofing truck.
Old Jan 9, 2009 | 04:53 PM
0Cajun @ Edgyvette
Former Vendor
Is there a ceramic spray coating I can buy?
To Rubberized undercoating and heat?
Old Jan 9, 2009 | 05:45 PM
hotwheels57
Check THE EASTWOOD COMPANY website and see if they might have anything...I kind of doubt it, but if anyone has something like that, it's them.
I doubt you'll find any of it in bulk, but asbestos was well known for heat and sound insulation...at the expense of your lungs.
I wonder if LINE-X or similar bed coatings would have any benefit other than a thick coating for sound insulation.
JET HOT will coat just about anything. I've had suspension parts as well as exhaust parts done.
Old Jan 9, 2009 | 06:03 PM
lucky131969
Yep. You just have to find an oven big enough to fit the tunnel plate in, and cure at 500 degrees.
Old Jan 9, 2009 | 07:24 PM
AU N EGL's Avatar
AU N EGL
you do know the tunnel plate will KEEP THE HEAT IN.
3" exhaust does a great job of getting the heat out.
Sounds wicked too
