New battery recommendations?
If that had been a Redtop or Exide Orbital, I have no doubt that whatever drained the OEM so quickly would have done even faster to the AGMs. The C6s are notorious for having electrical issues - most of them not the fault of the battery.
You can obtain a part number by visiting this page:
http://parts-catalog.acdelco.com/b2c/catalog_search.php
I would go with the ACDelco Professional grade battery which has a 50 month full replacement warranty. If you are concerned about side post batteries leaking, change the battery cables to a top post design as used in 2004.
conventional batteries sweat, leak corrode. whatever you call it, it sucks
I would not use anything that could leak
my optima has zero issues in this regard
not one bit of corrsion anywhere
and my last one lasted 7+ years and was clean all around
I HAVE read of AGM batteries that leaked, so I guess no one should buy them as well?
). Is the Optima 75/25 red top a direct drop-in replacement? I want to use the factory hold down clamp and I don't want any surprises when my car arrives and I have to replace the battery on the transporter. Thanks for everyone's input.
I have always had muscle cars and more recently, a Corvette. In winter, I don't drive them, and I have always had to regularly charge the batteries on these cars. Many guys use battery tenders (small trickle chargers) if car is being stored. Bottom line - all batteries steadily lose voltage as they sit. Therefore, "dead battery" does not always mean "bad battery".
, I've been using them for at least 15 years. Just changed one out last week, been in service since
