C5Z vs a modded C5
Old Jan 29, 2009 | 05:08 PM
uracowman's Avatar
uracowman
Default C5Z vs a modded C5
I am having an argument with someone and I need some clarification. Who would win from a 50 roll or a stop?
A stock 02+ Z OR
01+ C5 w/ longtube and a dyno tune?
Old Jan 29, 2009 | 05:44 PM
Bill Dearborn's Avatar
Bill Dearborn
What difference does it make? Take them to a track where you can run through the gears at speed and see which one completes a lap first. Its the package not just the engine and if there aren't a few corners thrown in the test is uninteresting. By the way you are forgetting the Z has different transmission ratios in first through third gears. As I said it is the package.
Bill
Old Jan 29, 2009 | 05:53 PM
Higgs Boson's Avatar
Higgs Boson
It would be close given different the gearing and weight. All things considered, I would go with the Z.
Old Jan 29, 2009 | 06:00 PM
Drewstein's Avatar
Drewstein
Until you go cam or gears I would side with the Z as well.
Old Jan 29, 2009 | 06:41 PM
CS Vette's Avatar
CS Vette
Gear ratios on the LS1 are a big advantage for roll racing (on a very very long closed course that is ). Even so, with equal drivers, it will still be a close race.
In theory... of course...
Old Jan 29, 2009 | 07:14 PM
Steve20's Avatar
Steve20
Haven't seen 360 net on an C5 with headers and tune--I would say Z by a long shot
Steve
Old Jan 29, 2009 | 08:58 PM
kendo347's Avatar
kendo347
I would say it is a toss up from a roll but from stop I believe the z would win if both drivers were equal, but not by much. The z should have 10-20hp more and a little lighter. I don't know if I remember correctly, but I believe the coupe had a higher top speed than the z because of less drag or gears or maybe both.
Old Jan 29, 2009 | 09:40 PM
black98c5's Avatar
black98c5
Both drivers being equal, I'll give it to the Z for sure. You would need at least a cam in addition to LT's and possibly gears.
Old Jan 29, 2009 | 10:46 PM
NVTHIS's Avatar
NVTHIS
From: Piedmont, SC Currently Own: 99 Nassau blue FRC. Previously Owned: 84,95,98 Indy Pace,01 Z06
I say the Z would take the win.
Old Jan 29, 2009 | 11:27 PM
Ryan L's Avatar
Ryan L
Until a 13.2 car can run 12.4s with only exhaust, then this is an easy one to call.
Old Jan 30, 2009 | 03:53 AM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
C5Z all day long.
Old Jan 30, 2009 | 06:13 AM
Brice's Avatar
Brice
Topspeed yes but from a roll shorter gearing win.
I bet on the Z !
(I have a 99 moded with ARH longtubes/Honker/Tuned)
Old Jan 30, 2009 | 01:43 PM
SilentFright's Avatar
SilentFright
From: Arlington Texas, originally from San Angelo, TX
I bet on the Z !
MN12 gearing trumps MN6 from a roll. I ran an 11.90 in my Z with Nitto 555R drag radials and a Vararam. Good luck.
Gear Ratios
Platform: MN6 MN12
1st Gear 2.66:1 2.97:1
2nd Gear 1.78:1 2.07:1
3rd Gear 1.30:1 1.43:1
4th Gear 1.00:1 1.00:1 <---- Only common gear
5th Gear 0.74:1 0.84:1
6th Gear 0.50:1 0.56:1
Reverse 2.90:1 3.28:1
Old Jan 30, 2009 | 05:03 PM
AU N EGL's Avatar
AU N EGL
the Z will win, unless you want to spend $10K min to upgrade the coupe and reduce the coupe wt.
Old Jan 30, 2009 | 07:06 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Hands down the Z.
Old Jan 30, 2009 | 07:30 PM
Bad97ta's Avatar
Bad97ta
wow 10k huh. o-k
Old Jan 30, 2009 | 07:52 PM
kendo347's Avatar
kendo347
Give me 10k and you would think the person in the z had a hole cut in the floor board and was pushing the z with his feet.
To C5Z vs a modded C5
Old Jan 30, 2009 | 08:07 PM
Bad97ta's Avatar
Bad97ta
yea 10 grand was a big number to use
Old Jan 30, 2009 | 08:19 PM
uracowman's Avatar
uracowman
lmao....
Old Jan 30, 2009 | 08:22 PM
AU N EGL's Avatar
AU N EGL
good set of 243 heads( ti Intake & Na exhaust valves) , good cam, timing chain, UP pully, LTs, High flow cats, smooth flow x-pipe and open exhaust, a CAI plus a darn good dyno tune. Suspension upgrade, add up all those part costs
Then taking the extra wt out of the coupe, light seats are a big place, and almost 60 lbs, carpet in the coupe is 60 lbs, the ~ 40 lbs. So yes taking off 200 some lbs out of the coupe takes some money, plus labor Darn close to 10K
That is about what it took me to get to 400 rwhp and 405 or so rwtq
But yes I also like the look of a coupe over the hardtop
and I prefer the MN6 gear ratio over the MN12 ratio. except for 5th gear on the MN12
