Check Engine Light help
Old Mar 3, 2009 | 09:16 AM
Orrville84's Avatar
Orrville84
2nd Gear
Default Check Engine Light help
I recently installed a new T-56 6-speed transmission in my 99 C5 and the new transmission doesnt have the skip shift on it at all. So, when the transmission shop put it in they left the connections to the skip shift disconnected and now i have a check engine light on because the computer is seeing the open circuit for the skip shift. Does anyone know if a skip shift eliminator will be able to shut the light off, or is there any other way to get the light off without disabling the check engine light itself? i really dont want to not have that light working at all but I also dont want to have the light on all the time. Any thoughts or ideas would be appreciated, thank you
Old Mar 3, 2009 | 09:32 AM
dougbfresh's Avatar
dougbfresh
Yes, it will shut the light off. You can test this with a 220 ohm 1/2 watt resistor.
Old Mar 3, 2009 | 11:25 AM
Orrville84's Avatar
Orrville84
2nd Gear
sweet, thank you I wanted to be sure before I ordered one that it would work. i Appreciate your help
To Check Engine Light help
