Help!! Crank is loose again
Old Mar 19, 2009 | 08:45 PM
miami993c297's Avatar
miami993c297
Originally Posted by vettenuts
That one is pinned with the ATI kit as it has a keyway milled in the hub.
Thank you for the confirmation, I am going to order it.
Christian
Old Mar 19, 2009 | 08:47 PM
vettenuts's Avatar
vettenuts
Christian
I have installed the Powerbond and the one I did had the milling for the pin. When you order, just confirm it is milled for the pin.
Old Mar 19, 2009 | 10:42 PM
vsocks1's Avatar
vsocks1
Do you mean the keyway or is it something special for the pin?
Old Mar 20, 2009 | 05:43 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you examine the damper HUB in these pictures, you will see that there is a KEY WAY running down the length of the hub.
When you use the ATI pinning kit, you place a machined tool steel guide on the crank snout. The guide has drilled holes in it that accepts drill guides. You use a drill to drill the side of the crank snout and then a ream to finial boar the hole to a press fit size for the small steel pin that gets fitted into the hole. Once the pin is fitted/pressed into the hole, you can slide the Powerbond damper on to the crank snout over the pin.
The pin prevents the damper from spinning on the crank snout which allows the damper bolt to come loose.
In my opinion, the ATI pinning method is superior to the other method of pinning but,,thats just my opinion.
I had the fear that pinning the crank was going to be difficult and time consuming. In fact, it took longer to gather up the drill and other tools to start the job than it did to do the job. Very easy!
Old Mar 20, 2009 | 06:15 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Hi Bill,
Is the Powerbond 25% UD Corvette Balancer Pulley #25-PBU1117SS25 @ $199.99 the crank pinned one you are talking about?
REF: http://www.texas-speed.com/shop/item...d=629&catid=16
Thanks in advance
Christian
Christian
PS: I just spinned my second ASP on my new 416...
YES!!! Same one that I used!! Very happy with it!
BC
Old Mar 20, 2009 | 07:14 AM
miami993c297
BC
Hi Bill,
Thank you for the detailed procedure.
Order is placed.
Christian
Old Mar 27, 2009 | 03:04 PM
miami993c297
Does this procedure seems right to you?
What did I miss?
Check for damage on Crankshaft (and eventually metal shaving through the engine) after extraction of the “new” freshly mounted ASP Pulley
Identify the Key Hole inside the Scat 4340 LS1 4.000 crank and insert the appropriate Key
Change and replace OIL SEAL with OEM one
Warm up the Powerbond Pulley @ 200°F for 40’ in an oven and align the Powerbond Keyway vs. the crankshaft key
Use MOLYLUBE on ARP bolt for tightening
First pass is something like 38 ft lbs.
NEXT AND MOST IMPORTANT is the torque 140 DEGREES of rotation.
Use the provided Serpentine Belt, and replace other belt if necessary
Christian
Old Mar 27, 2009 | 05:14 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The ARP bolt gets TORQED to 240 ft/lbs and does NOT get angled torqed!!
Hope I caght you in time..
BC
Old Mar 27, 2009 | 08:54 PM
miami993c297
BC
Right on time Bill...I hope I didn't disturb your BD party...Thank you again to clear that important point.
Christian
Old Mar 28, 2009 | 12:29 AM
vsocks1's Avatar
vsocks1
I read ARP revised the torque spec to 190 ft. lbs. I would call ARP to verify and use the ARP moly lube on the bolt!
Old Mar 30, 2009 | 09:38 PM
Kurtomac's Avatar
Kurtomac
bump....whats the tq spec for arp....i never had an issue with the stock bolt and 240 lbs of tq...im about to remove for a cam swap and using a arp bolt this time....dont have plans of pinning my crank as Im NA
Old Apr 1, 2009 | 12:25 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Curt
Im NA also BUT,,,,,,,,,,,,,pinning is very easy and good insurance that you WONT have an issue. I pinned mine and glad i did..
If you have access to a pinning kit,,,DO IT!
BC
