Help!! Crank is loose again
Old Mar 13, 2009 | 07:03 AM
TransAm2002's Avatar
TransAm2002
Default Help!! Crank is loose again
So I had a issue with my crank bolt coming loose. Don't know why. Replaced the bolt again, took it to 240 lbs and now it has come loose again. Any ideas what this could be from? Thanks for any help. Car is an 03 Z06 with heads/cam full bolt ons and 150 shot.
Old Mar 13, 2009 | 07:21 AM
C4B4the04's Avatar
C4B4the04
I am not sure where the 240 ft lbs comes from. That is the torque to mount the balancer but the GM book is VERY specific about first and second passes being done on the bolt.
New bolt, red loctite. First pass is something like 38 ft lbs. NEXT AND MOST IMPORTANT is the torque 140 DEGREES of rotation. If you dont have a degree index, get one. cheap and easy to use.
http://www.matcotools.com/ProductImages/tag281.jpg
Theres a picture of one. 140 degrees takes EVERYTHING I have to get it that tight (6' 190lbs and in shape) on a 26 inch breaker bar. Longer pipe would make it easier, but I couldn't get the space under the car. My torque wrench is a 250 pounder and it pops LOOONG before I reach 140 degrees.
Sorry you have to do the job again man, just sounds like the bolt is not tight enough. Unless the threads are galled up, which you would know as you pull the bolt back out, you are good to go.
Cassidy
Old Mar 13, 2009 | 07:47 AM
vsocks1's Avatar
vsocks1
Remember that you can't reuse the GM bolt. Go buy a new one and do it right!
Old Mar 13, 2009 | 07:49 AM
FRCTony's Avatar
FRCTony
Pin the crank? The nitrous might be spinning it.
Old Mar 13, 2009 | 04:19 PM
TransAm2002
Have always used a new bolt and done the right procedure to tighten it up. This is the second time. First time was on the N20 this time was on the motor.
Old Mar 13, 2009 | 04:39 PM
Tech's Avatar
Tech
Crankshaft is out of balance and the pulley is walking off. You probably thrashed your main bearings and sent metal throughout the engine. Rebuild time.
Just kidding. I've never had this problem. Perhaps an ARP bolt would be worth a try.
Old Mar 13, 2009 | 05:16 PM
vettenuts's Avatar
vettenuts
If you re-used your stock pulley I have always felt that it loses some of its interference fit and it more likely to spin than a new one. Correct procedure should be followed too, but I have always had a suspicion that re-use contributes to this happening.
Old Mar 13, 2009 | 06:02 PM
TransAm2002
Going to pin the crank and use red locktite so this doesn't happen again.
Old Mar 13, 2009 | 08:33 PM
vettenuts's Avatar
vettenuts
I wouldn't use red loctite, not called for or necessary and it won't prevent it from rotating. There are other factors that cause this to happen.
Old Mar 13, 2009 | 09:34 PM
T_Vert's Avatar
T_Vert
ive always reused my bolt and used red loctite. never once backed out..
Old Mar 13, 2009 | 09:55 PM
7thson's Avatar
7thson
ARP bolt. 25 buck and reusable.
Old Mar 14, 2009 | 01:31 AM
Jeff Jeff's Avatar
Jeff Jeff
Take it to a shop that knows what they are doing.
I did my own h/c job back in '02. Pulley got lose after 50 miles. Took it to a local shop that specializes in vettes, no problems since. Worth the $$ for the fact that they know how to it, and did it right.
Old Mar 14, 2009 | 05:57 AM
Blow Torch's Avatar
Blow Torch
If the stock pulley has spun twice, there's an issue. While it's apart, get a another pulley (go with UD for a few more hp) and pin the crank. The pulley is spinnig on the crank and backing out the bolt.
Old Mar 14, 2009 | 06:17 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Heres what you need to do to resolve your issue.
Remove all the old crap and trash the old stuff. Purchase a new Powerbond damper. The power bond damper has a key way that will allow you to side pin the crank. Beg, borrow or purchase a side crank pinning kit and pin the crank. That process sounds very complicated but,,,,it is amazingly simple and takes about 30 minutes TOPS to preform.
The crank snout is most likely worn from the old dampers spinning on the crank shaft (which is normally machined to a TIGHT press fit with the stock damper. ) and will not support installing a stock or an aftermarket damper without pinning. The pin prevents the damper from slipping or spinning on the crank. That movement causes the bolt to come loose.
Pin the crank and install a new Powerbond damper.
Bill Curlee
Old Mar 14, 2009 | 09:01 AM
TransAm2002
Thanks everyone should be fixed today.
Old Mar 14, 2009 | 11:45 AM
KCJeff's Avatar
KCJeff
Replaced my stock crank pulley with Powerbond (as suggested above). We used an ARP bolt (that's where the 240 ft lbs spec comes from). No problems since. No pinning. 125 shot on my stock bottom end.
Old Mar 19, 2009 | 07:11 AM
miami993c297's Avatar
miami993c297
Hi Bill,
Is the Powerbond 25% UD Corvette Balancer Pulley #25-PBU1117SS25 @ $199.99 the crank pinned one you are talking about?
REF: http://www.texas-speed.com/shop/item...d=629&catid=16
Thanks in advance
Christian
PS: I just spinned my second ASP on my new 416...
Bill Curlee
To Help!! Crank is loose again
Old Mar 19, 2009 | 09:38 AM
T_Vert's Avatar
T_Vert
You can pin any crank and balancer. Even a stock balancer can be pinned. Just use an A&A crank pinning tool. I can lend you one for the cost of shipping if you'd like. It even has a pin in there, all you need is a drill bit (that may even be in there)
Dave
Old Mar 19, 2009 | 09:44 AM
VGLNTE1's Avatar
VGLNTE1
St. Jude Donor '14-'15
red lock tight dosnt mean poop if you are TQing this bolt that much. I switched to the ARP bolt when I built my 416. if it keeps coming loose, something is not jiving.
Old Mar 19, 2009 | 05:52 PM
vettenuts's Avatar
vettenuts
Originally Posted by miami993c297
Hi Bill,
Thanks in advance
Christian
That one is pinned with the ATI kit as it has a keyway milled in the hub.
