cleaning valves in head?
Old Mar 16, 2009 | 10:49 AM
Tikiman12's Avatar
Tikiman12
Default cleaning valves in head?
Howdy, i'm about to change rockers and springs. and i was wondering if i need to or if there is a proper way to clean the valves before i reasimble the heads?
Do i need to clean them?
How do i clean them?
is it simple enough todo?
thanx
Old Mar 16, 2009 | 10:54 AM
jedblanks's Avatar
jedblanks
You could have a local machine shop "lap" the valves and clean up the heads if you have them off.
Old Mar 16, 2009 | 04:03 PM
Tikiman12's Avatar
Tikiman12
o, no i was just talking about getting the "build up" off teh valves idk if I can do that by hand or not. if there was some special trick, or if it even needs to be done
Old Mar 16, 2009 | 07:26 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you have all the rockers OFF the heads, then all the valves are SHUT. Go to AutoZone and find a product from Sea Foam called CREEP. It's the same stuff as Seafoam but its in a spray can, Spray the backs of each valve and let it sit over night. Then used compressed air to remove as much of the build up as possible. Be careful!!. When you blast it with air, all kinds of stuff can come out! Wear a face shield!
Spray the valves again and use some NON ABRASIVE tools to help dislodge the heavy deposits that didnt get removed and blow out the debrie again until its clean on the back of the valve and in the runner.
That should get 75%-80% of the deposits off the valves.
BC
Old Mar 16, 2009 | 07:39 PM
ANTIVENM's Avatar
ANTIVENM
Spray the valves with carb cleaner to loosen the buildup then take wd-40 and a piece of brown scotch-brite and go to town. This will NOT hurt the valves in any way! Also I would lap the valves.
Old Mar 17, 2009 | 08:14 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I believe that he still has the heads installed on the block! So lapping the valves is not an option.
BC
Old Mar 17, 2009 | 03:47 PM
Tikiman12's Avatar
Tikiman12
yes correct. the heads are on the car. i was just gonna clean what i could, and wanted to know how. Yall have helped greatly thank you
To cleaning valves in head?
