Tick Performance Adj. Master Cylinder (pics)
Old Mar 18, 2009 | 04:19 PM
robz's Avatar
robz
Originally Posted by 7thson
Honestly without that I would still be on my back dropping nuts on my forehead.
Not a great image, but thanks for the review.
Old Mar 18, 2009 | 04:28 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Originally Posted by Chevy Nick
The Tick Performance Adjustable Master Cylinder is one of the best modifications I have done to my car. I have a Textralia clutch, and my car shifts 3x better than it did with stock Mc. This thing is worth every penny. GREAT MODIFICATION.
Im looking forward to it
HAHA
Old Mar 18, 2009 | 04:51 PM
ColeTrain'sC5's Avatar
ColeTrain'sC5
i wanna try changing that on min before i change the clutch. See if it fixes my sticking clutch pedal
Old Mar 18, 2009 | 05:53 PM
Corvette-Chris
St. Jude Donor '08
Thats exactly what I thought. I knew I needed to bleed a little air out but I figured since I am doing a twin turbo build, I better spend the $300 and get a good fix.
I also figured I would spend $300 before I sprung for a $1200-$1500 twin disk clutch
Old Mar 18, 2009 | 07:03 PM
spiral04's Avatar
spiral04
I had the sticky clutch pedal and also hard getting into gear with the stock 04 clutch with 444rwhp and 414tq. I put in a Spec twin recently and the sticky clutch pedal is gone, although I do still have a hard time getting into gear at high rpms so it looks like a Tick adjustable is in this weeks future!
Old Mar 19, 2009 | 01:11 PM
SilentFright's Avatar
SilentFright
From: Arlington Texas, originally from San Angelo, TX
I just ordered the Tick master cylinder because of resistant engagement at high rpm (Ram twin-disk "street dual"). I hope this fixes things. After reading the above posts I am pretty confident it will.
Old Mar 20, 2009 | 04:24 PM
rich65's Avatar
rich65
Does anybody know if this tick cylinder fixes the sticky clutch problem? If it does i'm ordering it asap. thanks
Old Mar 20, 2009 | 04:35 PM
ColeTrain'sC5
if it'll prolong my ability to not go nuts with my sticking clutch for this year yet i will try it out. i'm hoping it's not TOO hard to install
Old Mar 20, 2009 | 06:05 PM
Chevy Nick's Avatar
Chevy Nick
my guess would be yes, it should solve any clutch hydraulic/disengagement issues.
Old Mar 20, 2009 | 06:08 PM
spiral04's Avatar
spiral04
I ordered mine from Tick today so hope this does the trick!!
Old Mar 20, 2009 | 07:17 PM
Corvette-Chris
St. Jude Donor '08
From what I have read, I think everyone will be happy with it. It just sucks I have to wait a while longer to test mine out
Old Mar 20, 2009 | 08:59 PM
7thson's Avatar
7thson
I knew that was coming..
Old Mar 21, 2009 | 07:29 AM
  #33
rich65's Avatar
rich65
Ok, Thanks i'm ordering mine also and thanks for the dyi instuctions it doesnt look easy
Old Mar 21, 2009 | 07:36 AM
  #34
rich65's Avatar
rich65
Really hoping this takes care of the sticky cluych syndrome cuz thats a pita
Old Mar 24, 2009 | 09:24 PM
  #35
SilentFright
It is really not that bad of a job. I got the old master cylinder (Ram adjustable), hydraulic line, and reservoir pulled in about 30 minutes. The clutch pedal assembly came out in another 10 minutes (use a 13mm gear wrench). I just got done drilling the two holes required to mount the new Tilton master. Tomorrow afternoon I will finish up. I assume the only frustrating part will be getting the 3 nuts that hold the clutch pedal assembly back on the studs.
Old Mar 24, 2009 | 09:50 PM
  #36
rich65's Avatar
rich65
Any tips are greatly appreciated cuz i'm installing mine friday
Old Mar 24, 2009 | 10:42 PM
  #37
Corvette-Chris
St. Jude Donor '08
You are correct, that was the only semi-frustrating part.
To Tick Performance Adj. Master Cylinder (pics)
Old Mar 25, 2009 | 06:44 PM
  #38
rich65's Avatar
rich65
Mine arrived today and hoping to get it in friday if the weather is good.
Old Mar 25, 2009 | 07:04 PM
  #39
golfinz's Avatar
golfinz
I wonder if one could buy the MC straight from tilton and build their own adjustable MC...this should save a few $$$. Any thoughts on which model this MC is...Im thinking its the 75 series. If not then a Tick will definitely be in order.
Old Mar 25, 2009 | 07:35 PM
  #40
LCZ06's Avatar
LCZ06
Great write up. Still not sure which adj. master cylinder I want to go with yet. $300 is steep, but it looks worth the price
