Tick Performance Adj. Master Cylinder (pics)
Old Mar 25, 2009 | 08:07 PM
  #41
spiral04's Avatar
spiral04
Originally Posted by golfinz
I wonder if one could buy the MC straight from tilton and build their own adjustable MC...this should save a few $$$. Any thoughts on which model this MC is...Im thinking its the 75 series. If not then a Tick will definitely be in order.
See recent thread on home brew master cylinder
Old Mar 27, 2009 | 04:13 PM
  #42
rich65's Avatar
rich65
Just installed the tick today and what a PITA. Trying to adjust it when i go to far the one way slips bad,think i have it ok now but the clutch lets out all the way at the top.Not sure if thats right but it is ok for bangin the gears cuz i don't have to push clutch in far. Any info on adjusting would be great.Also ran it a couple times and my clutch never stuck to the floor,so thats great. Thanks for the help guys.
Old Mar 27, 2009 | 07:22 PM
  #43
nextime's Avatar
nextime
Excellent photos!
Old Mar 28, 2009 | 04:09 PM
  #44
slothy's Avatar
slothy
Originally Posted by LCZ06
Great write up. Still not sure which adj. master cylinder I want to go with yet. $300 is steep, but it looks worth the price
http://forums.corvetteforum.com/c5-t...its-279-a.html
Old Mar 29, 2009 | 07:21 AM
  #45
7thson's Avatar
7thson
Back off the adjustment or you will damage your pressure plate by over compressing it.
Old Mar 31, 2009 | 12:20 AM
  #46
SilentFright's Avatar
SilentFright
From: Arlington Texas, originally from San Angelo, TX
Well my verdict is in on the Tick (Tilton) master. I can now shift at 6850-6900rpm with the greatest of ease (Ram twin-disk). I no longer get blocked due to inadequate pressure plate disengagement. Well worth the money in my opinion.
Old Mar 31, 2009 | 12:32 AM
  #47
golfinz's Avatar
golfinz
How was the install? Mind helping a fellow texan with one in the near future?
Old Mar 31, 2009 | 12:41 AM
  #48
KCvetteowner's Avatar
KCvetteowner
I like the tick as well BUT....as mentioned earlier, the hardest part is adjusting it and knowing what is ideal. I have it engaging close to the floor but after 3 weeks I still haven't installed that lower access panel under the dash
Old Mar 31, 2009 | 12:48 AM
  #49
SilentFright
Don't feel bad I broke my close-out panel during the removal.
Old Mar 31, 2009 | 12:52 AM
  #50
SilentFright
The install was not too bad. Getting the clutch pedal bracket with the Tick master cylinder attached back into position was an interesting situation (I am claustrophobic). After that getting the nuts back onto the studs was a blast (extreme sarcasm). I could walk you through it no problem. I am just being a wuss as it was really pretty simple.
Old Mar 31, 2009 | 08:03 AM
  #51
rich65's Avatar
rich65
When i adjust mine to far in the pedal gets sloppy and when i rev it up to hit the next gear it just slips,if i shift normal it's ok so i'm not sure how i need to adjust it yet. Any tips would be great. Thanks KCvetteowner for the install help very detailed instructions and pics. Mine seems to only work when the pedal grabs at the top of travel but i'm worried about breakin pressure plate but as i said earlier when i adjust it in it slips but i have a stock clutch if that matters. Thanks
Old Mar 31, 2009 | 10:08 AM
  #52
KCvetteowner
That doesn't sound good, how old is your stock clutch?
Old Mar 31, 2009 | 11:39 AM
  #53
rich65's Avatar
rich65
I have 30000 miles on it. Thats it. Like i said when i make it grab lower it slips and its sloppy at the top but where i have it now it grabs at the top but shifts fine. Do you think i'm doing something wrong? My pedal doesn't stick to the floor anymore at high rpm shifting like it use to.
Old Apr 8, 2009 | 03:12 PM
  #54
Chevy Nick's Avatar
Chevy Nick
If the car shifts well at the current position, then just drive it like that and enjoy it. You know your car and can get feedback better than anybody on this forum.
Old Apr 8, 2009 | 07:45 PM
  #55
rich65's Avatar
rich65
I just put the clutch spring back in , i know it doesn't say to reinstall it but i figured i'd see what it would do. It made the clutch so much easier and i'm not sure if i like it like that anymore. It did take care of the sticky clutch problem and i also wrapped the slave hose with extra heat tape cuz it's so close to the headers.
Old May 4, 2009 | 10:37 PM
  #56
Z06PSI's Avatar
Z06PSI
St. Jude Donor '17-'18-'19
I just bought this to go along with my Spec V and also replaced the slave. The old slave that was in there was actually sticking instead of moving easily up and down on the spring shaft like the new one. Could be your culprit.
Old May 7, 2009 | 11:24 AM
  #57
Joey@Tick's Avatar
0Joey@Tick
Former Vendor
Thank you guys for all the kind words - anybody local to us that wants one of these installed - we only charge 2 hours ($160).
If any of you have any questions about our kit or about how our kit could improve your setup, please don't hesitate to give me a buzz or shoot me a PM.
We want you all shifting your C5s like this:
To Tick Performance Adj. Master Cylinder (pics)
Old May 7, 2009 | 01:42 PM
  #58
roushraven's Avatar
roushraven
Coolest Guy Evar!
The Tick MC replacement of the OEM MC definitely eliminated my RPS Street Twin engagement/disengagement problem.
_RR
Old May 7, 2009 | 10:26 PM
  #59
molten vett's Avatar
molten vett
I'll be giving you guys a call next week.
I know this is good for aftermarket clutches but,have you installed it on any cars with stock clutches and had goos results? I have sticky pedal and problems getting into 3rd @ 6000rpm's
Old May 8, 2009 | 09:29 AM
  #60
Joey@Tick's Avatar
0Joey@Tick
Former Vendor
We've installed and sold a ton of these things for use on cars with stock clutches with great results.
