TPMS Bypass?
Old Apr 9, 2009 | 10:28 AM
DpunUSAF's Avatar
DpunUSAF
Default TPMS Bypass?
I picked up some aftermarket wheels that are not friendly to TPMS Sensors, does anybody know if there is a bypass product of any kind on the market, or some nifty trick to "tricking" the system so I dont have to see the annoying message every time I turn the ignition???? I know this is prob. an old question asked lots of times, but any help would be appriciated!
Thanks!
Old Apr 9, 2009 | 10:45 AM
timemender's Avatar
timemender
Not for the 1997-2000 C5’s. The 2001-2004 C5’s can have the feature programmed out of the BCM.
You can have them strapped to the rim inside the tire, and they will work that way. Locate them near the stem so that you will know where they are located, so that you can program them with a magnet.
Old Apr 9, 2009 | 11:10 AM
slothy's Avatar
slothy
check the mustang forums, they were making sealed pods with the tire sensors in them and tossing them in trunk.
Old Apr 9, 2009 | 11:11 AM
slothy's Avatar
slothy
http://allfordmustangs.com/forums/20...rk-around.html
Old Apr 9, 2009 | 11:20 AM
Corvette Don's Avatar
Corvette Don
Wont work as they need to "spin" above 15mph at least for the 1st gen sensors
Old Apr 9, 2009 | 11:22 AM
timemender's Avatar
timemender
You could put them in a pressurized bag hang them out the side window and twirl the bag while driving.
Most mustang people are not too bright. But I repeat myself.
Old Apr 11, 2009 | 10:38 AM
DpunUSAF's Avatar
DpunUSAF
Default Thanks!
Thanks guys, those are some interesting ideas haha, I would have never thought of holding it out the window like that...how could I not look cool doin that haha! Anyway, I am curious, you said to strap it to the inside of the wheel, that is an interesting idea, epoxy maybe?????
Old Apr 11, 2009 | 11:48 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There are several products available that allow you to easily attach the seasors inside the rim and retain the feature on any aftermarket rim. One of them has a special mount that you install as a valve stem and that valve stem has a holder on it.
I tried to use the search function to fine the post but the search feature is HOSED!!!
There out there and work very well!!!!!!!
Old Apr 11, 2009 | 11:54 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Tire pressure sensor mounting brackets
Ahhhh,,,,found the post!!!!!!!!
http://forums.corvetteforum.com/c5-t...em-wheels.html
Old Apr 12, 2009 | 10:41 AM
7thgeneration's Avatar
7thgeneration
To have this programmed out of the BCM, is this something the dealer has to do ? Or is there another source ?
Old Apr 12, 2009 | 01:04 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
It can only be accomplished using a GM Tech II. Dealers have then BUT,,,,,,so do outside garages and privite individules. Most good corvette shops and tuners have them and can use them to do that.
BC
Old Apr 12, 2009 | 02:46 PM
Hall1836's Avatar
Hall1836
Most dealers will not turn them off, but will turn them on if previously off or putting sensors on a Z06. Federal law from 2007 prevents them from deactivating the TPM.
Old Apr 14, 2009 | 12:46 PM
DpunUSAF's Avatar
DpunUSAF
Default Wow
Originally Posted by Bill Curlee
wow! that looks like it will work for me, THANKS BILL!
Old Apr 14, 2009 | 01:02 PM
clif's Avatar
clif
St. Jude Donor '09-'10
Old Jul 5, 2009 | 10:11 AM
GEO 8's Avatar
GEO 8
Did anyone help you disable them.........i have a 2000 and just bought a set of tires that have 2001 in them?
Old Jul 5, 2009 | 10:50 AM
AU N EGL's Avatar
AU N EGL
just hit the reset button.
and no problems
Old Jul 5, 2009 | 10:51 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
97-2000 C5 do not have the ability in the BCm to DISABLE the TPMS
2001+ have that ability! You can add or delete them using the GM Tech II I added them to my 02 ZO6.
Old Jul 5, 2009 | 11:13 AM
GEO 8's Avatar
GEO 8
Was looking for something more permenant....lol
Old Jul 5, 2009 | 11:57 AM
timemender's Avatar
timemender
Having Tire Pressure Sensors on non-runflats are a good idea as you will get an early warning with a slow leak. Of course they are a MUST with runflats.
You can change the TPMS (and Key-fob) receiver to use the less expensive 2001-2004 TPS & 2001-2004 fobs.
See this thread –
http://forums.corvetteforum.com/c5-t...e-sensors.html
To TPMS Bypass?
