engine gurus only please.........
Old Apr 13, 2009 | 03:12 PM
VGLNTE1's Avatar
VGLNTE1
St. Jude Donor '14-'15
Default engine gurus only please.........
I just built my 416 LS3 from SDPC about 4000 miles ago. It runs strong as hell...but I am loosing oil down the sides of the block. Not enough to drip in the ground, but its all over the block. Looks to be seeping out where the heads meet the block. They are L92 heads that are milled and ported. I used ARP bolts. Currently I am using .60 thickness gaskets. Could they have gone bad after such a short time? I have some .45's in the garage...can I just change these out without worring of a big CR change?
the leak is not from the front cover, nor valley......no idea why the heads are lifting
Old Apr 13, 2009 | 03:28 PM
NassyVette's Avatar
NassyVette
What brand and bore size are the head gaskets?
Old Apr 13, 2009 | 03:30 PM
VGLNTE1's Avatar
VGLNTE1
i just asked for them when I was buying the motor...I imagine GM? I dunno
they are 4" bore.
Old Apr 13, 2009 | 03:41 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Check PM
Old Apr 14, 2009 | 03:11 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Theres ZERO pressurized oil in the heads. The lifters get oil thru the lifter bores and the rockers get oil through the push-rods and the oil drains back into the block through the areas around the head-bolts.
Pressurized oil can and will leak out of the OIL PRESSURE SENDING UNIT!
Thats the very first place that I would check.
BC
Old Apr 14, 2009 | 03:37 PM
zeevette's Avatar
zeevette
they are 4" bore.
I would think they're at least 4.06" bore.
Old Apr 14, 2009 | 03:46 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I thought I had a SERIOUS oil leak. I had oil everywhere. I wiped down the entire engine and found that the timing chain cover seal for the damper was allowing oil to leak during high speed blast due to higher crank case pressures during WOT runs.
Wipe down the engine and do a short normal drive and then check the engine. Then do a high speed blast and see if you see any leaks.
BC
Old Apr 14, 2009 | 03:57 PM
VGLNTE1's Avatar
VGLNTE1
BC
i had that same problem on my 346....I have looked at the front cover..its dry
Old Apr 14, 2009 | 04:38 PM
a4troy's Avatar
a4troy
try some dye and a black light?
Old Apr 14, 2009 | 06:01 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
OIL PRESSURE SENDER!
BC
Old Apr 15, 2009 | 01:47 AM
rustyguns's Avatar
rustyguns
BC
Old Apr 15, 2009 | 12:37 PM
VGLNTE1's Avatar
VGLNTE1
BC
the oil pump?
Old Apr 16, 2009 | 10:21 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
the oil pump?
Oil pressure sender is behind the intake manifold.
Old Apr 16, 2009 | 10:54 AM
95BlueBomber's Avatar
95BlueBomber
Hmm I noticed the same issue on mine before my rebuild, never thought to check the oil pressure sender.
Old Apr 16, 2009 | 03:51 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
I agree sometimes the plastic will separate from the brass or AL and it will leak. Still register but leak. Take a look back there.
Old Apr 17, 2009 | 08:34 AM
VGLNTE1's Avatar
VGLNTE1
seems to still be PCV issues....the tube from the valve cover was spewing oil to the air bridge and running out of the TB then down the sides of the block....from what it looks like. Im not sure this LS3 valley cover has a internal valve....nothing seems to work for a PCV for me. I just have it vented to the atmosphere now
To engine gurus only please.........
