help
Old Apr 20, 2009 | 04:13 PM
my_bigmike's Avatar
my_bigmike
Default help
okey guys i have 1997 corvette the car locks and unlock by it self i turn the car off get out wait a couple of min and it locks and unlock and it keep doing that all day and some times when i drive it the sec light comes on turn the car off and turn it back on its gone any ideas?
Old Apr 20, 2009 | 04:53 PM
glkfam's Avatar
glkfam
Obviously this is exactly what the passive switch on the remote key fob does when it comes close to the car. If you have the passive key fob and walk around the car it will unlock and lock the doors continuously as you move by or away from the car. Have you tried to reset or reprogram your passive key fob? That would be the first thing I would try. Does this happen only when you are by your car and have the key fob on you. Or will it happen even if you leave the key fob in the house. If it happens when you do not have your key fob by the car, I would definitely look at the reciever/antenna by the rear tire in the hatch compartment. Could be defective, but I would lean towards something with the passive key fob. Maybe if you turn the passive key fob feature off on your key fob and it still behaves like this, I would go directly to the key fob that the off feature isn’t working any longer on your key fob. Contacts dirty inside fob, etc. Hope this helps or opens a door for you to find the problem. It is a weird one. But sometimes weird problems end up being the easy ones.
Old Apr 20, 2009 | 05:27 PM
my_bigmike's Avatar
my_bigmike
u know that could be it it seems to happen when im near the car i didnt know about the passive switch but i think i had it on on im going to try off and set near it see if it helps sometimes i get my secerty light on do u think its the same resone and thanks for the help
Old Apr 20, 2009 | 07:37 PM
buoniconti81's Avatar
buoniconti81
Its prob the key fob. Take it apart and gets some electrical dustoff... Hopefully that helps...
Old Apr 20, 2009 | 07:54 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Turn the PASSIVE feature OFF on the FOB and in the DIC. That way, it will NOT read the FOB on its own and react.
That feature was discontinued in 99 for that very reason. No one really liked the way it worked (or didnt work)
Old Apr 20, 2009 | 09:25 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Hey Bill, FYI only, some of the '99's got that feature too including mine. Its certainly a PITA.
To help
