Royal Purple users.... Read this!
Where headers added onto the car?
What were the conditions before the oil change?
What oil was in it previously and how old was it?
Nothing else was changed. I did a bunch of digging and the wheel well tick is pretty common in 4.6 OHC mustangs so I think it will be fine. I may try a different oil next time.
I unplugged each injector one at a time and it didn't effect the noise.
It has long tubes but its not a header leak.
Brakes-Non Performance--Just use a good Brake Fluid for your Specfic Car.
Brakes-Performance--Motul Dot 4 racing brake fluid (RBF600)
Clutch Fluid-Always Performace--Motul Dot 4 (RBF600)
Note: Motul has a very high wet boiling point, thats whats important
C5 & C6 Stock Short Block Engines--All get Mobil 1 (unless customer wants something different)
C5 & C6 Built Short Block Engines--Get whatever the builder says
C5 & C6 Stock Automatics--Valvoline ATF Dex-Mer III or any equal
C5 & C6 Built Automatics--Royal Purple ATF
C5 & C6 Stock Manuals--Valvoline ATF Dex-Mer III
C5 & C6 Built Manuals--Royal Purple Syncromax
C5 & C6 Stock Diff's--Valvoine 75-90 FULL Synthetic or Mobil FULL Syn
C5 & C6 Built Diff's--Royal Purple 75-90 Full Synthetic
We have a customer that has a 1997 C5 with over 316,000 Miles on a stock never been into LS1!! Mobil 1, Thats pretty good.
This is just our opinion.
So BP's own expert, in a blind comparison, found RP produced .9% more power than Castrol. Not up to RP's claims of 3%, but still, more power.
Using 350 HP as a start, that's 3.15 HP more with RP than Castrol.
405 HP 3.65 HP
505 HP 4.55 HP
I'll keep using RP.
