Bill Curlee - EBCM/Electrical Problems
Old May 11, 2009 | 10:55 PM
D2Brewing's Avatar
D2Brewing
Default Bill Curlee - EBCM/Electrical Problems
Bill (and anyone else)...
2002 Vert, slightly modified (intake/exhaust/etc). Replaced the EBCM after it's initial failure back in Nov. Last week, I had a bunch of codes hit at once:
C1248
C1255
B0026
U1160
C1283
and I started getting a "Service Vehicle Soon" message on the DIC. I reset the codes, and the C1248 and C1255 come back immediately, and the C1283 shows up eventually. The others are gone, but I still get the "Service Vehicle Soon" warning.
Additionally, the steering feels stiffer than normal (however, this could purely be psycho-somatic...)
This occurred in the rain (I rarely drive in the rain), and it seems the EBCM is dead again, but the "Service..." message and the stiffer steering has me worried.
Any ideas?
Thanks,
Dave
Old May 12, 2009 | 03:31 PM
DeeGee's Avatar
DeeGee
Not the standard bunch of codes
I'd be trying the grounds first
Look at Bills electrical sticky and clean up the grounds to see if it improves
It could be the EBCM but I'd try the simple fixes first.
Old May 12, 2009 | 03:49 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Holy Crap,,,,,your EBTCM isnt happy!
Check the grounds just like DEEGEE stated!
Second,, I would disconnect the main connector and inspect the winchester plug and EBTCM connector. Make sure that there in good shape. Make sure that the wires inside the connector are not damaged or broken.
When you replaced the EBTCM,,,,did you make sure that the seal between the BPMV body and the EBTCM was 100% good. If it isnt, the module may have moisture in it. Thats the next thing that i would check.
The EBTCM makes all the calcuations for active handling and if its not doing them properly, the C1283 DTC will set Excessive time to center steering wheel.
Never seen C1248 DRP Disabled before, Ill have to look that one up!
Old May 12, 2009 | 07:19 PM
D2Brewing's Avatar
D2Brewing
<<Holy Crap,,,,,your EBTCM isnt happy! >>
I love it when those are the first words out of Bill's mouth...
Both - thanks for the feedback. I'll have to dig into it this weekend. I'll let you know what I find (or more likely, have follow up questions... )
Old May 19, 2009 | 08:42 PM
D2Brewing's Avatar
D2Brewing
Checked the G101 and G102 grounds. G101 was clean, G102 was corroded. I cleaned it, but no cigar. I wasn't able to check the EBTCM connectors, will try that this coming weekend.
If the connection is clean, does this look like a relay failure (absfixer), or a bigger failure?
Old May 19, 2009 | 09:12 PM
Bill Dearborn's Avatar
Bill Dearborn
In addition to checking the EBCM connector check the EBCM ground at G108 over by the battery. The ground by the left headlight is for the BPMV. Check the fluid level in the master cylinder and check to see if the parking brake is on or the sensor indicates it is on. C1255 indicates the EBCM has an internal electronics failure. However, C1283 could be caused by the EBCM, the steering wheel position sensor or the lateral accel sensor or by not receiving signals from them. If there is corrosion in the EBCM connector it could be causing these codes. If you don't find a ground or connector problem or something like low brake fluid/parking brake on it looks like the EBCM is toast.
Bill
Old May 19, 2009 | 09:42 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Bill
Bill
I think you left out 3 or 4 things!
BC
Old May 19, 2009 | 09:46 PM
Bill Dearborn
Originally Posted by Bill Curlee
Bill
BC
Alas, I try.
Bill
Old May 20, 2009 | 11:50 AM
voda1's Avatar
voda1
After cleaning grounds do you use anything to prevent future corrosion?
Old May 20, 2009 | 02:45 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YES!! I use something called CORROSIONX. There are other products that do the same thing. Boat places sell som electrical corrosion preventative compounds.
BC
Old May 27, 2009 | 06:51 PM
D2Brewing's Avatar
D2Brewing
Sorry I haven't posted...
I followed the Bill Curlee's advice, no luck. As a side note, the grounds near the headlights were just like Bill's sticky - one was immaculate, the other was corroded.
I'll look at Bill Dearborn's suggestions this weekend.
Thanks, guys! I'll post the next round of results...
Old May 29, 2009 | 11:22 AM
voda1's Avatar
voda1
BC
That would be for the outside of the terminal/connector much like the corrosion protection spray for top post battery terminals? For cleaning the terminals inside a connector use a electronic/electrical cleaner. But is there any product to protect against future corrosion of the terminals inside the connector?
Do you use any type of grease/sealer to help seal the weatherpak connector?
Old May 29, 2009 | 11:40 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YES. The thick film CORROSIONX fully protectes the terminals exposed or not from any moisture or frett corrosion. It works very well!
Bill
Old Sep 4, 2012 | 08:39 AM
LUVmyCORVETTE's Avatar
LUVmyCORVETTE
1st Gear
Default won't start due to electrical problem
Good morning Bill,
My name is Kimberly and from Jacksonville, FL.
My 2003 50th Anniversary Special Edition won't start due to electrical problem and was advised by Jerry Hamm Chevrolet to trade in the car due to costs and not being able to find the cause. Battery brand new and brand new ignition switch. Any idea as to the cause of no start? Really don't want to trade due to economy. Please help and advise.
Thank you so much, Kimberly
Old Sep 4, 2012 | 09:54 AM
chaase's Avatar
chaase
St. Jude Donor '12
Originally Posted by LUVmyCORVETTE
Good morning Bill,
Kim,
I would suggest starting a new thread with your symptoms and the list of codes. You can use the following link to help. http://www.stengel.net/diccodes.htm
That is the first step for any diagnosis.
Old Sep 4, 2012 | 11:48 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Good morning Bill,
KIMBERLY
You are at a STEALERSHIP.
They see MONEY DRIPPING out of your pocket and into theirs!
Any mechanic that can not figure out why a C5 wont start is either CROOKED, INCOMPENET, STUPID or ALL THREE!!!!! When we get your car to run properly, you can QUOTE me on that!
My STRONGEST recommendation is to:
RUN KIMBERLY,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,R UN away!!
PM sent with my phone number!
Bill
Old Sep 4, 2012 | 04:39 PM
kernelPanicked's Avatar
kernelPanicked
STEALERSHIP
Why would they want the trade-in if this is such an expensive problem to fix? Was there a sign out front that said "Dead Corvette Storage?" No? Well that's because storing dead Corvettes ain't their business! Selling them new and used, on the other hand, is. I, too, am glad you didn't listen.
To Bill Curlee - EBCM/Electrical Problems
