Real-life experience with active handling?
Old May 27, 2009 | 03:35 PM
black99stk's Avatar
black99stk
These are Great Stories.. Haven t had any experience yet
Old May 27, 2009 | 03:56 PM
DeeGee's Avatar
DeeGee
Originally Posted by Dope
Actually it's about 500hp at the flywheel and C5s have independent rears, not live axles. But I'm nitpicking.
I also drive my mildly-modded 98 Camaro SS year-round, especially as my primary transportation through the rough winters we get here in the Northeast. Have been doing so for 10 years. No AH on that one either.
To me, relying on a computer to save your bacon is dumb. Learning to drive is a better option. I've gotta buy one of those little gizmos that automatically turns off your AH every time you start the car!
Dope
I saw the thread a few weeks ago with the pics of the member that wiped his car out on a storage unit. He'd switched off AH and the pics weren't pretty.
Some can; many can't.
the Tornado I flew wouldn't fly without computers. the F4 I flew didn't have one. Each had its strengths and vices but it was designed to do a job. Cars are the same. If AH is not needed why did GM install it? Mainly for the average driver who has worked out that he's not invincible. And before you ask, I've had friends kill themselves in computer controlled aircraft, low power cars and motor bikes. I learned on a manual 37 years ago, I've had one accident, lived in England, Italy, Germany and the US and driven in most European countries. The max speed I made in a jet was Mach 2.1 and in a car 176. Oh, and it rains in England. I think I can drive.......................
If you have the experience go for it. Most drivers don't. There are Old Pilots and Bold Pilots; But there are no old, bold pilots
I've survived and my car is in one piece after 6 years but I trust the AH when its needed. I turn it off when it's not - but that's not often..
Out.
Old May 27, 2009 | 04:14 PM
Bill Dearborn's Avatar
Bill Dearborn
The best way to find out how it works is to go to an autocross and drive through a slalom with AH in Comp mode. That way you will feel it applying a single brake to yaw the car in the direction you intend to go. Don't try to exaggerate your steering moves. Just drive the way you would with a car that doesn't have AH and you will see what it does and doesn't do. By the way I have never had it pull throttle except when I leave the TC on. It doesn't fight the driver it assists the driver by yawing the car in the direction the driver is trying to make it go. The smoother you are the less it activates.
Bill
Old May 27, 2009 | 04:35 PM
Airbase's Avatar
Airbase
empty
Old May 27, 2009 | 06:41 PM
Bill Dearborn
Originally Posted by Airbase
And before you read on, please understand that the miata outhandles the corvette. Yep, i said it, and i'm speaking the truth. I know many vette driver's dont believe me, go do some research if you dont, you will find i'm correct. Of course this applies to handling specifically, not the overall capability of the car, but specifically handling and lateral Gs. My miata was 1,000 lbs lighter than my C5, too. Ridiculously fun cars. It's SOO fun that it becomes a stupid amount of fun, and an addiction. Anyway....
I can verify they outhandle a Corvette. Its difficult to overcome a 1000 lb weight advantage. They will kill a Vette in an autocross but the Vette will kill them on a road course. The power and speed become a real advantage and the Vette can even corner faster than a Miata on some road course corners.
Of course the vette is harder to handle than a miata because of the additional horsepower and larger size, and the handling is epic but it's main advantage is it's wheelbase/layout and horsepower over the miata which makes it the overall more capable car. But the same basic skillset always applies.
What i'm getting at is i understand how to manage speed, braking, traction, track-out, correct oversteer, correct understeer, induce one if i desire it, etc etc...
So... Let's say i am going 60 and the corvette begins to oversteer. In the miata i'd countersteer before i even decided to, it's muscle memory. But in the corvette, i'm not sure i should, is the AH going to fix it for me? If i don't correct i might be okay, but if i do then i may confuse the AH and the vehicle will be receiving two inputs and possibly become unstable, possibly resulting in a crash?
The situation you describe can vary somewhat depending on what else you are doing. But I have a real life example of just that speed scenario from when I first got my 03Z. I was following another Z around the off camber left at Watkins Glen and had just started squeezing the throttle when the back end slipped to the right and back into line so fast I didn't have a chance to react to it. In the video you can see the nose of the car wiggle and hear the engine rpms pick up as the rear wheels spun a little and then it was over. The speed was right in the mid 50s area.
I have road-coursed a few other high hp cars like an NSX, but they weren't mine to own, so i didnt push them 10/10 hard. I havn't had the time to race my own corvette either, save for a single half-sized free autocross put on by a local church (it was actually alright!), but i had everything turned off.
When i oversteer at 60, i'm not sure if i should countersteer, because if i do i may induce incorrect rotation due to the interaction between myself and the AH.
...What's the real story with this? I have to be absolutely positive i understand the system intimately in every conceivable way before i attempt to actually begin to try it out.
Do what comes naturally. The system assists you by determing if the car is yawing properly to follow your commands through the steering wheel.
When you do a slalom in an autocross you will get a lot of push and then maybe some power oversteer. When the front end starts to push you will feel the back inside brake being applied. Depending on how hard you are running it sometimes feels like somebody is hitting the car with a sledge hammer. As the car transitions into oversteer the front wheels start having the brake applied to slow down the sideways movement of the tail. As long as you are in comp mode the EBCM will not reduce power.
The biggest problem with using AH in an autocross is getting it to turn on in time to have any affect. Each time the engine is started the system resets so it has to recalibrate to find out where straight ahead is located. This takes driving in a straight line at over 6 mph for 200 ft or so. Hard to find a place to do that at an autocross. If you don't do that then it will set a warning message Active Handling Warming Up and about the time you finish the run it will then say Warm Up completed. However, if you don't turn off the engine the system will be calibrated for your next run.
Do as you are planning and go out and have some fun with it. One thing it can do that you can't is allow you to apply full power coming out of a slow corner and keep the back end from squirting out from under you. I did that in one autocross where we had a 90 degree corner before heading down a 150 ft straight to the finish line. As I came around the corner in 2nd I floored it and the car just vibrated as the front brakes kept switching back and forth to keep the car in a straight line. The rear wheels were spinning lightly. Everybody kept asking how I was getting off that corner so fast. So once you know how it works and behaves you can actually use it for an advantage.
Bill
Old May 27, 2009 | 09:34 PM
Atok's Avatar
Atok
The AH system has a steering input sensor. If you correct the oversteer the AH system knows this and will not fight you.
Old May 27, 2009 | 11:14 PM
petercln's Avatar
petercln
Thats not true for the first generation AH systems. If I try that with my 98(when it was stock too) the car thought I wanted to go in the direction I was pointing the tires to, I can get the car to swing side to side. The first time that happend I was glad no one was around. And this was on a dry road.
Now on my 04 the AH was totally predicatable and safe for anyone to use.
Old May 28, 2009 | 03:23 AM
ZeeOSix's Avatar
ZeeOSix
Originally Posted by Torch FRC
I was coming around a corner on a mountain road on a rainy day. I got on the gas mid corner and got sideways....b4 I could say $%*& the car hit the brakes and straightened me out. I probably would have saved it but Im rather glad I didnt find out!
Similar "saved my ****" senario when hammering it in 2nd gear on tight, dry pavement corners. Rear end would snap out in a split second, but the AH kicked in and reduced power, braked the appropriate wheels and straighted the car out pretty fast .... I was impressed. If it was turned off, I'd probably would have at least did a 180 on the road and maybe even put it in the ditch. Things happen real fast when the "torque monster" is let loose.
Old May 28, 2009 | 11:15 AM
aawatson170's Avatar
aawatson170
Originally Posted by CUZIWIN
Old May 28, 2009 | 11:16 AM
aawatson170
Originally Posted by kerryt1
Competitive Driving = AH on, TC off. That's my MO.
Old May 28, 2009 | 11:47 AM
ericdwong's Avatar
ericdwong
No active handling with my 98 I wish I had it though, but I do disable the traction control with a laptrax.
Old May 28, 2009 | 12:05 PM
Boo383's Avatar
Boo383
For the vast majority of drivers AH is a good thing and I know it has possibly saved me once or twice. I say possibly because it works so fast. Perhaps I could have saved it myself but AH straightened me out before I could even start to react.
Old May 28, 2009 | 01:12 PM
  #33
Bill Dearborn
That is what it is supposed to do. Wherever you are pointing the front tires is where you want to go. If you are steering into a skid (oversteer) you are pointing the tires in the direction you want to go. Yes, the car can swing side to side as it corrects. Same thing can happen to a person as well. Nothing to get nervous about.
Bill
Old May 28, 2009 | 01:30 PM
  #34
Pwrtrip75's Avatar
Pwrtrip75
I hate it. its almost killed me a couple times. when you need to hammer on it and get over out of traffic....oh no...you go nowhere because the stupid active handling comes on and your stuck limping and almost causing an accident. Same with CAGS.... Many times i need to go for 2nd and avoid getting hit and im stuck there like a wounded deer limping in 4th or trying to find a gear.
Old May 28, 2009 | 02:04 PM
  #35
Bluefire's Avatar
Bluefire
That's not the AH. That is the TC pulling timing.
Old May 28, 2009 | 04:02 PM
  #36
C5X2C's Avatar
C5X2C
I leave my AH on when I'm on the streets, but off when I'm on the track, it over-reacts to everything. It was always tugging at me and slowing me down and I wasn't sliding the car or breaking traction in the least. It must be confused!
Old May 28, 2009 | 05:50 PM
  #37
Atok's Avatar
Atok
I don't think it's the active handling that almost killed you... it's the driver behind the wheel.
To Real-life experience with active handling?
Old May 28, 2009 | 08:21 PM
  #38
Chevy Guy's Avatar
Chevy Guy
Exaggerate much? Traction Control (not AH) wont pull power if you dont spin the tires and CAGS only kicks in 1st to 2nd when under 20mph.
Old May 29, 2009 | 07:35 AM
  #39
Pwrtrip75's Avatar
Pwrtrip75
Right, AH is what displays on the dash and its all controlled by the same button. I have to get the HPtuners lisence for this car yet to zero out all the -timing in the TC tables. Other than that I havnt noticed AH doing anything else. They should have had a seperate button for TC and AH.
The way I drive is usually if I have to get on it I throw it into 2nd that way it dont spin the tires as easily. Usually around the same speed CAGS kicks in. Im just lazy and havnt deleted it yet.. But it is the DUMBEST thing GM ever did...CAGS.. lol.
Old May 29, 2009 | 08:25 AM
  #40
AU N EGL's Avatar
AU N EGL
Miatas are great little handling cars. put the right foot on the floor and leave it there, well almost.
I also agree that many Miatas in the hands of a capable driver will out handle and out drive a corvette on a short tight curvie road course.
Try getting into a 3400 lb car with 350+ hP plant the right foot on the floor and attempt to drive that same tight curvie road course, NOT going to happen or
TWO different Cars that require TWO different driving styles.
the details of AH / TC and tq mangament were given above.
Learing to drive safely, smoothly and effortlessly takes practice lots of seat time.
( I did not say slow either ) and to do this type of driving at speed takes even more seat time.
AH / TC saves lives, all cars and light trucks even mitias will have AH/ TC ( IIRC) by 2010 or 2013 - those gov mandates.
Race cars are different. Learning to slide ( not drift) a car ever so slightly though a high speed corner takes seat time, practice BIG ***** and a bit of crazyness. ( I think those last too go together) and NEW STICKY TIRES. Which is not for street driving.
for public street driving I leave it ON. On the road race courses, OFF
