Need some advice -- Crazy Blow by on basically new engine
On disassembly, found a ring land cracked (area between the rings). I assume one of the rings popped out of the ring compressor and got hung-up when installing the pistons. Since it was a fresh build, I just replaced the one piston/rings and all was good again.
Also during initial break-in, it's good to open-up the throttle, abt 1/2 way, at low to mid rpms to help seat the rings. Just don't the rpms get too high. I keep them below 3000 for the first 300 miles.
No, they were not oversized, as far as hone goes, I dont know, but I will find out....The build was supposedly done outside the car, I live about two hours away so I never visually saw the motor out of the car, but I assume it was because when I got the car back the steering wheel was crooked....
The gentlemen is very appologetic about what has happened, and is willing to do the leak down test to see where the problem is, however, either way the motor has to come back out, so in your opinion, what should I do, let him proceed and repair the one or more cylinder(s), or should I just buy a new short block, which I can get for around 35ish, and have him or someone put that in, because I do not want to have to do this again, I am afraid that there may be permanent damage to my block, such as honed too much, or etc,,,,,,
The lowest risk might be to go with the short block depending where you purchase it from. Your current one might be repaired, but knowing nothing about the person doing the work it is hard to gauge if this would turn out good or bad.
If it were me, I'd go with a short block from a known good source.
Best of luck!
Is it functioning correctly????
Thats the first thing that I would check. Make sure that its free flowing and the PCV valve is the correct one and functioning correctly!
BC
