Please helpppppppppppppppp. Please help
Old Jun 8, 2009 | 06:23 PM
Joe Tagliarini's Avatar
Joe Tagliarini
Default Please helpppppppppppppppp. Please help
HI, I HAVE 98 CORVETTE CONVERTIBLE..
I HAVE A BIG PROBLEM, MY MECHANIC COULD NOT FING THE BIG PROBLEM..
MY MECHANIC SAYIND THE -- IAT(Intake Air Temperature) SENSOR AND THE ECT(Engine Coolant Temperature) SENSOR IS SHOWING IN THE SCANNER -40 DEGREE,AND THIS IS NOT RIGHT..
please help me,, my car is in the mechanic for 2 months and time cost money...
Old Jun 8, 2009 | 06:25 PM
vettenuts's Avatar
vettenuts
Joe,
Get the car back, those two items should then need replacing are very simple to replace. What is the car doing and why would it take him that long to replace such simple parts?
Old Jun 8, 2009 | 06:41 PM
huttler's Avatar
huttler
This can be fixed in 30 minutes.. Was the car in for any other repairs? Sounds like a lawsuit waiting to happen
Old Jun 8, 2009 | 06:53 PM
dougbfresh's Avatar
dougbfresh
Why double post this? What's the big deal anyway??? Just have him change them if you trust him. If not take it somewhere else.
Old Jun 8, 2009 | 06:59 PM
ljthe2nd's Avatar
ljthe2nd
How many time are you going to post this. I've found 3. Once is all you need to post! If the mods see this they will close the duplicate posts.
Old Jun 8, 2009 | 09:17 PM
Joe Tagliarini
we ready replace the iat and the ect sensors and nothing yeah...
anybody know what happing??
Old Jun 8, 2009 | 09:40 PM
highpockets's Avatar
highpockets
Very simple really. Your computer is not receiving data from the new sensors ! Could be a loose connection,wire pulled out,wire pinched/cut or faulty computer(unlikely) Start with the ECT,its easiest,trace the circuit(two wire) from the sensor on the dr cylinder head front,to the plug on the computer.Once that is fixed,you can attack the IAT. Follow precisely the trouble tree/repair track using GM approved procedures and you will not have any problems.
Old Jun 8, 2009 | 10:28 PM
byronhunter's Avatar
byronhunter
You're going to need this and another mechanic!!!!!!!!!!!!!!!!!!!!Pull the codes from the DIC and post them here.
Old Jun 8, 2009 | 10:36 PM
dougbfresh's Avatar
dougbfresh
So many possibilities Who is smarter, you or your mechanic?
2 months in the shop and you have to ask what to do?
Old Jun 8, 2009 | 10:46 PM
ArKay99's Avatar
ArKay99
Well, looking at the schematic posted here the problem is one of 2 things. The 5V is not being applied to one side of the sensors, or the ground sides of the sensors are not connected. I would follow the 5V feed to the fuse. I'll bet the fuse is blown, or not installed.
Have him measure the 5V side of each wire in each connector and verify if the voltage is there. Put one probe of the meter into the connector, then the other to a ground point. If you see voltage, then put the meter into each pin of the connector. If you measure voltage, then the part is bad.
Old Jun 9, 2009 | 09:52 AM
MattB's Avatar
MattB
IMO its the wires near the connectors that can fail with both of these sensors. The replacement connectors have pretty long wires with them, just have them splice the new connectors in and keep the new wires pretty long. The connectors are pretty cheap, and it won't take long to do. I'd do that before spending more money trying to trace the wires, especially since it sounds like the mechanic is not familiar with C5s.
Old Jun 9, 2009 | 10:56 AM
squidwards vert's Avatar
squidwards vert
Guys the OP has only been here since March, we all F-up the rules sometimes, maybe ease up a little. I'm sure he is frustrated is all.
To the OP, hang in there dude, you are getting some good advice. You probably need another mechanic IMO.
Best of luck
Old Jun 9, 2009 | 02:49 PM
Joe Tagliarini
hey guys thanks for everything..
but everything you guys it wroted he ready did before he make double check, he told me..
the computer sending messager for the sensors but the sensors is not send back..
the question it, is possible the problem is the pcm????
Old Jun 9, 2009 | 03:15 PM
MagRedConv's Avatar
MagRedConv
Don't read this the wrong way but...get the car to a real mechanic. It seems to me that you're doing as much troubleshooting as your "mechanic".
Old Jun 9, 2009 | 06:02 PM
Joe Tagliarini
what you mean??
i just need my car be fix..
he check everything you guys a top say, and still the problem.he ask help for gm dealer..
the gm dealer think is the pcm...
what do you guys think???
Old Jun 9, 2009 | 06:07 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
what you mean??
You need to go to a shop that has a Tech II. This should be a real simple fix.
Old Jun 9, 2009 | 07:58 PM
crainholio's Avatar
crainholio
Take it to a Chevy dealer, the mechanic you're working with is not the right skill level.
To Please helpppppppppppppppp. Please help
Old Jun 9, 2009 | 08:41 PM
Joe Tagliarini
thanks guys...
Old Jun 12, 2009 | 02:45 PM
Joe Tagliarini
my mechanic think the problem is in the cluster, but nothing resolver yeah..
everything you guys at the top say, he ready did,so o told him if he not fix this weekend..next week i will take the car to other mechanic shop...
thank guys alot for everything...
Old Jun 12, 2009 | 03:03 PM
timemender's Avatar
timemender
Just be aware that some dealerships (like some repair shops) keep installing expensive parts on a car until the problem is fixed.
And, to add insult to injury, even if the problem is NOT resolved because of their incompetence in diagnosing, you still pay for their “hit and miss” experimenting.
Sometimes a problem with a component like the PCM is actually with the electrical connections (their plug-in terminals) because of poor (corroded) connectors and NOT the component itself.
I shudder at the thought of how many EXPENSIVE electrical components are replaced that are in good working condition.
