What did I do wrong? Brake Bleeding C5Z
Old Jun 13, 2009 | 06:29 PM
hpfiend's Avatar
hpfiend
Default What did I do wrong? Brake Bleeding C5Z
Hey all,
Ok in preparation for a first autox with my 2003 zo6 I tried to bleed the brakes. I emptied the master cylinder reservoir with a syringe and hose, then filled with Ford Motorcraft HD DOT 3, then pumped the pedal up.
I started with the passenger side rear, I put the mity-vac on and cranked it up, then I cracked open the bleeder and proceeded to flush/bleed from that wheel and it flushed perfectly with a full tube until the fluid looked new.
I then moved to the driver side front and I could not get the fluid to fill the hose no matter how I oriented the length of the mity vac hoses or the amount of suction, or how hard I pushed the hose onto the bleeder. I finally got a decent amout of fluid out but lots of bubbles that would not clear by cracking the bleeder WAY open and then way shut.
I moved to the driver side rear and got the same situation but I could not get as much fluid out of this one no matter what I did. I probably got it to look clear but still lots of bubbles and not acting right.
Then the passenger side front, perfect, nice solid stream, that would fill the mity vac hose.
The driver side seems like it is open somehow- I tried putting the cap on the master cylinder and there was no difference?
Did I somehow get air in the abs module or do I have some sort of blockage in my proportioning valve? The car has 16,000 miles and I assume the fluid to be original and it looked pretty nasty- I got it less than a year ago.
I drove the car around the block and the pedal feels about the same as it did before I started if not a tad bit spongier but power brake cars always have a bit of sponge in the beginning- I engaged abs at a hard 45-0 stop and it seemed to work fine but I want to be sure.
Thanks!
Andrew
Old Jun 13, 2009 | 07:03 PM
AU N EGL's Avatar
AU N EGL
Need pressure to PUSH the fluid though, not pull with mini vac.
Motive Power Bleeder with 18-22 psi
Old Jun 13, 2009 | 09:57 PM
Wheelyneat's Avatar
Wheelyneat
I've never had much luck using a Myti-Vac to bleed brakes. I agree with the previous post - use a pressure bleeder like the Motive and you should have no issues.
Old Jun 14, 2009 | 02:22 AM
Last C5's Avatar
Last C5
+2 for the Motive.
Old Jun 14, 2009 | 02:34 AM
Blown 346's Avatar
Blown 346
Always start with the furthest caliper away from the master cylinder.
Pass. Rear.
Driver Rear
Pass. Front
Driver front
Old Jun 14, 2009 | 06:27 AM
Wheelyneat's Avatar
Wheelyneat
Pass. Rear.
Driver Rear
Pass. Front
Driver front
This sequence does not apply to later C5s due to a brake system redesign. The sequence used by the OP (RR, LF, LR, RF) is correct for his year model.
Old Jun 14, 2009 | 06:37 AM
AU N EGL's Avatar
AU N EGL
I found it makes no difference which order. I do start with the RR.
Do RR, then LR
Pump brake peddle 3-4 times
Refile MC
RF
LF
pump brake peddle 3-4 times
Refil MC
pump brake peddle 3-5 times
take car for short drive
Old Jun 14, 2009 | 01:30 PM
hpfiend's Avatar
hpfiend
It sounds as if I need some new technology....
So I need some speed bleeders or the motive pressure bleeder?
Anyone have any idea why the passenger side works perfectly with the mity-vac and the drivers side is difficult? Noone thinks it is a proportioning valve/abs issue?
Thanks!
Andrew
Old Jun 14, 2009 | 01:43 PM
TEXHAWK0's Avatar
TEXHAWK0
Why don't you try just manually bleeding the brakes in the correct sequence first to see if you can get the system back to normal?
Old Jun 14, 2009 | 03:41 PM
TurboBerserker's Avatar
TurboBerserker
I've always heard you should not pull a vacuum on ABS breaks (since you are only pulling a vac between the caliper and the ABS module anyway, and risk damaging the ABS).
I personally use speed bleeders and bleed all ABS vehicles manually.
Old Jun 14, 2009 | 07:01 PM
hpfiend's Avatar
hpfiend
We just had a baby so my wife is not available to press the pedal on command which is why I did not do it manually.
Great :-( how do I tell if I damaged the ABS module?
I am going to order some speed bleeders this week.
Thanks,
Andrew
Old Jun 14, 2009 | 07:20 PM
vsocks1's Avatar
vsocks1
Speed bleeders work great!
Old Jun 14, 2009 | 07:25 PM
TurboBerserker
Thanks,
Andrew
What about the baby? Can't he or she reach the pedals?? Congrats BTW!
If your ABS is kaput, the computer will let you know. I'm not sure what the actual risk is with that part of the statement, but if your vette isn't screaming for you service the ABS I'd think you are fine.
Old Jun 15, 2009 | 04:43 PM
Fast one's Avatar
Fast one
The caliper piston seals are designed to keep the fluid in and air out as in a check valve, if vacuum is used at the master cylinder, air is sucked into the system around the caliper piston seals. All you need is a set of speed bleeders.
Old Jul 7, 2009 | 11:59 AM
hpfiend's Avatar
hpfiend
Thanks all for the advice and congratulations!
I ended up getting a set of stainless speed bleeders SB1010S-SS and they are awesome- brake pedal feels even better and I am again confident with the setup- nice innovation. On a side note I was probably supposed to throw the bag away but it was so neat I emptied it out and kept it for next time.
Thanks,
Andrew
Old Jul 7, 2009 | 03:41 PM
Dave68's Avatar
Dave68
Here's a bit of advice I read in Popular Mechanics and I agree:
When manually bleeding brake fluid using the brake pedal, place a wood block under the pedal to limit travel to approximately the travel the pedal (and master cylinder piston) "sees" during normal use. The reason is that the master cylinder piston sealing surface will eventually have a slight step in it, due to the very consistent travel distance of the piston and seal. Extending the piston past its usual stopping point is a good way to damage its seal.
This happened to a garage's mechanic who was flusing fluid from a van I used to have. When I picked up the van, the pedal was very mushy - not because of air inclusion, but because the master cylinder seal was damaged. When I found out how the mechanic bled the fluid, I told him he was responsible for the MC damage and he admitted that it made sense.
Old Jul 8, 2009 | 06:09 AM
Wheelyneat's Avatar
Wheelyneat
This is exactly why I use a pressure bleeder - I have had MC failures in other cars after brake bleeding using the old "pump the pedal" method. IMO the MC was not designed to be a repetitive long stroke hydraulic pump.
Old Jul 8, 2009 | 09:54 AM
Dave68's Avatar
Dave68
I agree that pressure bleeders are the way to go. Ever since I had my garage floor painted, however, I've had someone else to the flushing. It runs about $90 and saves my floor from having bare concrete circles under the four corners of any of my cars. One of these days, I'll look into epoxy flooring.......
Old Jul 8, 2009 | 11:04 AM
Drunken Master's Avatar
Drunken Master
To What did I do wrong? Brake Bleeding C5Z
