Cleaning hood insulation.....
Old Jun 20, 2009 | 04:43 PM
LT1vette's Avatar
LT1vette
Default Cleaning hood insulation.....
My hood insulation pad has some stains on it. Has anyone cleaned this pad and what did they use that wouldn't mark the engine compartment?
Something like " Simple Green" or "Fantastic" ?
Or, could you just use Krylon semi gloss black and paint it?
TIA
Old Jun 20, 2009 | 05:03 PM
SJPD's Avatar
SJPD
Old Jun 20, 2009 | 05:37 PM
hotwheels57's Avatar
hotwheels57
http://forums.corvetteforum.com/c5-t...tallation.html
http://forums.corvetteforum.com/c5-t...-hood-pad.html
Use "search this forum" in C5 Tech (in the red banner) using keywords, "hood blanket", "hood pad", "hood insulator", etc...
Old Jun 20, 2009 | 07:22 PM
TEXHAWK0's Avatar
TEXHAWK0
I would not wash it with any liquids unless you remove it.
I usually just vacuum mine to get the loose dirt with a soft brush attachment.
Old Jun 20, 2009 | 08:51 PM
LTCHAPPA's Avatar
LTCHAPPA
Vacuum with a soft brush attachment then spray paint it with flat black
Old Jun 20, 2009 | 10:12 PM
ALLEGRO's Avatar
ALLEGRO
Brush/vacuum it off and then spray the heck out of it. I used three "rattle cans" of semi-gloss before I painted the logo. After nearly six years, it still looks great, and because I painted it, I can merely brush off anything that gets on it.
Good Luck
Old Jun 21, 2009 | 12:00 AM
rws.1's Avatar
rws.1
I have 125K miles on my '01. the hood liner has been cleaned many times and painted once.
With it still mounted, I lift the hood, spray it wih a mixture of Simple Green ( 1 part S.G. to 3 parts water) let it soak 5 minutes.
Then i use my pressure washer on a broad fan setting and rinse it thoroughly.
I leave the hood up to let the liner drain and dry.
Old Jun 21, 2009 | 12:45 AM
Choreo's Avatar
Choreo
I do the same thing - I just cover my engine with plastic bags
Old Jun 21, 2009 | 04:14 AM
DeeGee's Avatar
DeeGee
Heres how I did it:
Refurbishing a Corvette C5 Hood Liner
The liner is made of a very delicate material so be careful in how you handle it once it’s removed. The surface is a fabric type finish and hard brushing will cause it to become rough and fibrous. It will also crack easily if you let it flex so if you take it outside beware of strong wind.
As you take the final fasteners out, support the liner so you don’t crack the liner around the eyelets.
The actual work takes only minutes. The drying time is the only slow process.
As you can see, the liner will have attracted quite a bit of dirt and grime.
OK here we go.
Lift the hood.
Remove the fasteners gently, top, then bottom and middle ones last. This will support the liner better as you take them out. Us a tool with a forked end. I’ve heard of a barbeque fork being used. I used a nail puller work in behind the fastener.
Take the liner outside and brush the surface gently with a soft brush to remove any dirt. Take care not to damage the surface of the liner.
Spray the liner with black paint. The difference between the old and the new surface is immediately apparent.
Use as many coats as you see fit. The liner is porous so it will take at least 3 coats to get good coverage. Leave it for 30 mins between coats to allow the paint to dry.
If you plan to paint the Corvette emblem, you may wish to apply extra paint around the embossed area on the liner. This will stop the liner absorbing the coloured paint.
Once the paint is dry (and you may wish to leave it overnight), you can either paint the emblem or apply a decal. I chose the decal. Alternatively if you prefer, you can refit the liner and apply the decal when it’s back in place.
Refit the liner in the hood fitting the middle fasteners first to hold it in place, then refit the remaining fasteners. A gentle push fit is all it takes to reinsert the fastener.
The finished Hood Liner
Old Jun 21, 2009 | 07:36 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Originally Posted by DeeGee
Heres how I did it:
Nice write-up.
Where do you get the decal?
To Cleaning hood insulation.....
