Solid engine mounts for DD use?
Old Jun 25, 2009 | 10:39 AM
TurboBerserker's Avatar
TurboBerserker
Default Solid engine mounts for DD use?
Hey guys,
What do you think about running solid engine mounts in a DD? I live in Rochester NY where there is no stop and go traffic. (Seriously, I've been in 2 stop-go driving situations in 2 years, both the result of a huge accident).
I figure there will be some increased vibration at idle, etc., but don't have anyway to judge how bad it will be in these cars.
Opinions, thoughts, advice; all welcome!
Old Jun 25, 2009 | 10:40 AM
lucky131969's Avatar
lucky131969
Sounds like a great idea...I think you should do it
Old Jun 25, 2009 | 10:46 AM
ecoman's Avatar
ecoman
Do a search I have seen some posts on this subject,Good luck
Old Jun 25, 2009 | 10:47 AM
timemender's Avatar
timemender
Solid mounts will place more stress on the aluminum block at the attaching points.
Seems like overkill on a “street” car. What possible benefit do you expect?
Old Jun 25, 2009 | 10:51 AM
TurboBerserker
I forgot to mention this will be used with an iron LSX 427 block.
The benefits are reduced "twist" in the drive train and more power to the rear tires.
Old Jun 25, 2009 | 12:03 PM
Evilash's Avatar
Evilash
I did near solid poly mounts and trans mount in my mustang. I loved it. The car felt more solid and the car seemed to react to my right foot more closely and less slop.
I fully plan to do it with this vette too using those PFADT mounts.
The mustang was cammed with a delrin bushing and spherical bearing suspension so NVH increase was negligable and not really a concern.
This vette is cammed and full exhaust and I don't believe it's going to increase NVH in a bad way.
Old Jun 25, 2009 | 12:11 PM
clif's Avatar
clif
St. Jude Donor '09-'10
I have the Phadt solid mount mounts in my car, and I do drive it daily. The only negative I found, it the engine vibration can now be felt in the passenger compartment when idling. Still, not a big deal. I would definitely do it again.
Old Jun 25, 2009 | 12:23 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Originally Posted by TurboBerserker
Hey guys,
I got a set for sale, cheap.
http://forums.corvetteforum.com/c5-p...ral-parts.html
Old Jun 25, 2009 | 12:24 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Where is this "twist" you speak of come from?
Old Jun 25, 2009 | 12:45 PM
clif's Avatar
clif
Here's my Phat mounts, along with my new Phadt diff brace (also the RSI Dual fule pump in the back ground!):
Old Jun 25, 2009 | 12:50 PM
TurboBerserker
Torque :P
Old Jun 25, 2009 | 12:54 PM
WKMCD's Avatar
WKMCD
Do poly mounts like the PFADT's but be prepared for enough vibration to make the DD ride unpleasant.
Old Jun 25, 2009 | 12:56 PM
lucky131969
You know, the twist you get with a full framed straight axle car........oh...wait a minute.....
Old Jun 25, 2009 | 02:03 PM
TurboBerserker
It's been proven that when you use the upgraded lime green blinker fluid, the engine still flexes against the motor mounts.
I used to advocate the tangerine orange blinker fluid, but once I used tang by mistake.
Old Jun 25, 2009 | 02:06 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Old Jun 25, 2009 | 03:22 PM
AU N EGL's Avatar
AU N EGL
solid motor mounts = orbital sander pressed against you butt
not quite but with a race seat, ie no padding and solid mount bolted to the floor, it sure feels that way.
lime green blinker fluid ??????? darn now why didn't I think of that
To Solid engine mounts for DD use?
