Cam Question ms3
Old Jul 5, 2009 | 10:29 PM
Nate B's Avatar
Nate B
Default Cam Question ms3
I just ordered an ms3 cam from texas speed with a 112lsa and on the cam card it states it has 3 degrees advance ground in. I didnt specify any advance when i ordered the cam, Is that normal? Would i be better off with no advance ground in?
Old Jul 5, 2009 | 11:19 PM
eschantra's Avatar
eschantra
A little advance would help a bit with low end in a bigger cam. I had a fairly radical Comp Cams cam in my previous C3 that had a couple degrees advance ground in.
Old Jul 6, 2009 | 07:05 AM
AU N EGL's Avatar
AU N EGL
most cams have 4* advance ground in.
Bigger cams have more advance so they run at lower rpms.
Old Jul 6, 2009 | 08:17 AM
Nate B's Avatar
Nate B
So 3* is normal for this size cam? Im just concerned and dont want to put the wrong cam in. It didnt state anywhere that the cam was advanced and i have been told in the past to go with a 112lsa not 112+3.
Should i use the cam?
Old Jul 6, 2009 | 09:16 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
Agree with what others have said.
Might find this link helpful.
http://www.ls1tech.com/forums/genera...cam-guide.html
Old Jul 7, 2009 | 06:03 PM
Nate B's Avatar
Nate B
Thanks for the info. That helped a lot
To Cam Question ms3
