installed fast 92/90 WOW
Old Dec 23, 2009 | 10:05 AM
  #61
SDLS1Rider's Avatar
SDLS1Rider
Originally Posted by justin8018
the car made like 416 on a mustang dyno, but i beleive lost like 30 ft lbs of torque haha, afrs seemed perfect 12.5- 13.0 and even added 2 degrees of timing, i was kinda bummed actually, and kinda embarresed i just spend $1200 and lost torque and only gained 10 hp
What are your list of mods?
Old Dec 23, 2009 | 10:27 AM
  #62
justin8018's Avatar
justin8018
fast 92 90mm ls2 tb, 228 232 cam, longtubes, double springs, varram, now i have an uderdrive pulley that i didnt have when i dynoed it
Old Dec 23, 2009 | 12:14 PM
  #63
TheBigK's Avatar
TheBigK
Was this on the same dyno as the first #'s? Same tuner?
Old Dec 23, 2009 | 12:17 PM
  #64
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
It may be because you now have a stout intake going into stock LS6 heads...I usually see FAST intakes on at least Stg 2 ported LS6 heads. You really need a set of great flowing heads to maximize the gain of a FAST....So it almost sounds like a slight mismatch in parts. Just IMO
Old Dec 23, 2009 | 12:18 PM
  #65
justin8018's Avatar
justin8018
NOpe, nope haha, baseline was like 39x though after fast
Old Dec 23, 2009 | 12:20 PM
  #66
TheBigK's Avatar
TheBigK
I've seen the FAST work great on stock 243 heads. I guess anything can happen
Old Dec 23, 2009 | 12:21 PM
  #67
justin8018's Avatar
justin8018
and even ls1 heads
Old Dec 23, 2009 | 12:23 PM
  #68
clif's Avatar
clif
St. Jude Donor '09-'10
I also have a ported FAST 92, that I got Powder Coated to look nice. I installed a Lingenfelter 90MM TB. My car is so torquey!
Old Dec 23, 2009 | 07:17 PM
  #69
Dudeiwin86's Avatar
Dudeiwin86
so youre comparing your 'new' dyno results with the Fast90
to results you had on a totally different dyno?
might as well chunk any comparo youre trying to do out the window.
the only way to make any kind of comparo is same dyno, similar day.
