I put a breather on my oil fill and capped off the two areas where the PCV hoses used to attach.
My builder ported my FAST 90 with the heads attached (so they were port matched). The results speak for themselves and to me, the car is an absolute beast.
I believe Tony posted up a simple dremel fix to cure the whistling a couple months ago. If I recall it was a small piece of material causing the whistle.
The Mamo fix you reference is for the FAST 78mm intake. It had a sharp edge just behind the throttle body that would cause a whistle/squeal at part throttle acceleration. After putting up with it for a year I was thrilled to see Tony's post on how to radius the edge.
However, this isn't going to fix the whistle being described on the newer FAST 90 or 92 intakes. There is more than likely a vacuum leak.
From: Wylie TX --> Less is More, except under the hood !
Originally Posted by TheVetteLevel
One of these days you will. Your car pulls well as is. If i had one I would be tempted to paint the Fast intake they look great when painted.
The never ending search for more HP... ... Ill leave mine silver I think (when I get one)... It matches the color theme on my car anyways... . I agree, the painted ones look wicked !
Some nice setups in here - I've got a used 90 on the way to the house plus an LS2 TB that I'll port myself. So what are you guys running for the rubber coupling that attaches the LS2 TB to the cold air intake? I'm running speed density plus my MAF is up by the filter anyways so I just need a rubber "pipe" section to connect the LS2 TB to the Halltech CAI inlet...any ideas?
Got a 228/232 cam and lingenfelter edlebrock heads. Apointment with the dyno at va speed next friday!!! Finally time to get this tuned and back on the road!
Sorry for the hijack.
But how do you like those heads? Are they the Lingenfelter CNC Edelbrock #61969 heads? What kind of gains did you get with them. PM me if you want to.
Most guys are running some form of a smooth coupler. I have some question as to whether or not those things can collapse at full throttle. I guess it would primarily depend on their length (the longer length would make it more prone to collapsing).
the car made like 416 on a mustang dyno, but i beleive lost like 30 ft lbs of torque haha, afrs seemed perfect 12.5- 13.0 and even added 2 degrees of timing, i was kinda bummed actually, and kinda embarresed i just spend $1200 and lost torque and only gained 10 hp
