installed fast 92/90 WOW
Old Jul 22, 2009 | 12:11 PM
justin8018's Avatar
justin8018
well i was supposed to go the the dyno today, but got in a BUMPER BENDER!!!!!!!!
piSSED
just need new bumper and headlight door
PISSSSSEDDDDDDDD!!
will have numbers in a week or so, ill even Pm them to you :0
Old Jul 22, 2009 | 01:42 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Awesome! I picked up 24RWHP/19RWT over the LS6 intake. Mine was ported by Tony Mamo. FAST 90/90
Old Jul 22, 2009 | 01:53 PM
Blk Btty C5's Avatar
Blk Btty C5
cant wait to see those numbers
Old Jul 22, 2009 | 02:02 PM
jrmotorsports55's Avatar
jrmotorsports55
Bummer about the bumper bender. Saw you on Bagley on Monday.
Jason
Old Jul 22, 2009 | 02:03 PM
ExTurbo's Avatar
ExTurbo
Tony does great work, i got mine from him and it made a HUGE difference in part throttle performance...Full throttle was ridiculous after the swap
Old Jul 22, 2009 | 08:46 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
I got a cam approx that size also with AFR heads (448rwhp/432tq). I was told that I could get 20+ on HP and TQ. Man I wish money grew on trees !
Love to hear your gain when you find out ! Congrats on the boost !
Toque
Old Jul 22, 2009 | 09:03 PM
ZO6ME's Avatar
ZO6ME
Originally Posted by justin8018
bump for fast 92
They should be giving you commission for this. Just got my 92 today and waiting on the used LS2 90 tb that I bought off the forum. Already got Torquer v3 cam, asp pulley, Yella Terra's, ported LS6 tb and intake. Can't wait to feel the difference.
Old Jul 22, 2009 | 09:16 PM
corvette8189's Avatar
corvette8189
mine should be coming in monday
cant wait
ported fast 92 and ported LS2 TB
Old Jul 22, 2009 | 09:34 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
Toque
Your missing the final icing on the cake that every H/C car needs! A properly ported FAST will net you gains all across the powerband, not just up top. Not to mention a very crisp throttle response with no compromise with driveability. Search around, theres plenty of fantastic deals going on now for ported FAST intakes. My car was a different animal when I picked it up from ECS. Its a nice feeling when your own car scares you again
Old Jul 22, 2009 | 10:27 PM
Toque's Avatar
Toque
I know all too well... Its on my list for sure. Just strapped right now. One of these days I want to for sure !
Toque
Old Jul 23, 2009 | 02:48 PM
dmiz0420's Avatar
dmiz0420
I'm probably the only idiot who got a 92 and switched out the shell for the 78 to keep torque up. I'm using an 80 mm tb but I havn't gotten it dynoed yet. I also can get $350 for the shell.
Getting athe 92is nice but add in $250 to $300 for a ls2 tb and $50 harness adapter and one starts to wonder if a stock displacement 346 will benefit ffrom the 92. A year ago you could pick up an LS2 tb for < $150. Now there are some new 92 mm tb's coming out that you can bolt up the stock ls1 motor so you don't have to pay $50 for the $2 harness adapter.
If I can, I'll try doing back to back runs with the 78/80 vs the 92/90 to see.
Got a 228/232 cam and lingenfelter edlebrock heads. Apointment with the dyno at va speed next friday!!! Finally time to get this tuned and back on the road!
Old Jul 23, 2009 | 09:48 PM
happa's Avatar
happa
I would like to see the dyno results also.
Old Jul 23, 2009 | 10:53 PM
  #33
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I ported my own FAST 90 and 90mmTB. I took my time and removed plastic in critical air flow areas. Seems like I got excellent results. 450 RWHP. It wasnt difficult. Just time consuming. I was really careful as to not make it a $800. paper weight.
I was surprised at the ammount of plastic dust that was removed!
BC
Old Jul 24, 2009 | 01:50 AM
  #34
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
I believe Tony posted up a simple dremel fix to cure the whistling a couple months ago. If I recall it was a small piece of material causing the whistle.
Old Jul 25, 2009 | 09:13 PM
  #35
ZO6ME's Avatar
ZO6ME
Just installed my FAST 92 intake and I got the whistle. Where is this plastic you speak of or a link to Tony's write.
Old Jul 29, 2009 | 12:59 AM
  #36
corvette8189
wooohooo i got my fast installed today.
pics
is it ok just to cap the hose, cause theres no spot for it on the fast
Old Jul 29, 2009 | 08:53 AM
  #37
CTD's Avatar
CTD
That is the breather line for your crankcase, you need air.
When you removed the old intake was there a lot of oil puddling towards the front were TB mounts?
To installed fast 92/90 WOW
Old Jul 29, 2009 | 09:44 AM
  #38
Skinny Kid's Avatar
Skinny Kid
Don't cap it. I did and the car started squeaking in low rpm/high vacuum situations. It drove me nuts, but ended up being air being sucked past the crank seal. I've seen this on other FAST equipped cars as well. I just bought a $15 K&N breather with a 3/8" nipple and used a small piece of hose to couple it to the nipple on the valve cover. It's all hidden under the FRC's and no more squeaking.
Justin
Old Jul 29, 2009 | 01:59 PM
  #39
ovrpar6's Avatar
ovrpar6
I want one!
Old Jul 29, 2009 | 04:15 PM
  #40
corvette8189
alright i got a breather on it now.
when i start it up the thing idles at like 1500 then slowly comes down to 1000 but if i tap the gas it shoots up to 2500 then slowly comes back down. is this part of my tune, i have a speed density tune.
