Weird Movement!
Old Aug 4, 2009 | 11:57 AM
kmhpac's Avatar
kmhpac
7th Gear
Default Weird Movement!
With the engine off if the passenger opens their door I feel a 5 second movement within the car; like a vibration. This has happened several times. Drives fine otherwise.
Has anyone else felt it? I have a '99 vert with 13K.
Old Aug 4, 2009 | 01:04 PM
lucky131969's Avatar
lucky131969
What happens if you get out first, and the passenger stays in?
Old Aug 4, 2009 | 05:35 PM
kmhpac's Avatar
kmhpac
7th Gear
Don't know but will test it.
Old Aug 4, 2009 | 05:38 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Is this vibration something new or has it always done this?
Old Aug 4, 2009 | 05:43 PM
YNOT2K's Avatar
YNOT2K
you let passengers ride in your vette?
sorry, i have nothing else to offer.
jeff
Old Aug 5, 2009 | 02:04 PM
Eric D's Avatar
Eric D
The OP didn't give his/her location. Has there been any earthquake activity reported lately?
Old Aug 5, 2009 | 03:25 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Fans still running or winding down?
Old Aug 5, 2009 | 03:28 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The ONLY thing that the PASENGERS DOOR has incommon with control of the car is:
- The interior light.
- The security function. DOOR AJAR
If the door is causing some other body control or engine control function to change,,,, your most likely having a Serial Bus issue. The door wiring harnesses run thru the rubber accordion tube between the door and door frame. Pop out the accordion tube and fish out the connectors in the door frame. Carefully seperate the connectors and examine those wires and connectors. Look for corrosion, damaged wires, bent pins, etc!
Fix anything that you find bad. See if that fixes your issue.
BC
To Weird Movement!
