need urgent advice.
Old Aug 5, 2009 | 10:23 PM
tbiker99's Avatar
tbiker99
Default need urgent advice.
The MIL just came on. Pulled codes, P0433CH. I did some reading and it looks like its the "Evaporative Emission Control System Purge Control Valve Circuit Malfunction"
I reset the code and it came back. Since then, I've double checked the gas cap and I don't know if it will come back or not. (started drinking when I did the research).
Here's the kicker: I have to drive back home tomorrow after work, 200 miles. Do the experts think this will be a major issue? Normally I would park it until I could fix it. But as I said, I have to go home tomorrow. I don't have time to keep trouble shooting, and I can't take off to run it to the Chevy garage. What are the odds of permanent damage if the gas cap didn't fix it? Or will I just burn excess gas?
thanks, I really hate being in this situation...sucks.(I'm between rock and hard place.)
Old Aug 5, 2009 | 10:59 PM
lucky131969's Avatar
lucky131969
I can't find a P0433, is it possible is was a P0443?
Old Aug 5, 2009 | 11:02 PM
tbiker99's Avatar
tbiker99
Your right, P0443, as I said, I've had a couple drinks. I can't really blame the Jim Beam, I've made that same mistake 3 times while doing internet searches before I had my first drink.
thanks
tom
Old Aug 5, 2009 | 11:07 PM
lucky131969
You'll make it home...
Old Aug 5, 2009 | 11:17 PM
tbiker99's Avatar
tbiker99
thanks. It seems like half the people I know drive around with that check engine light on. Drives me crazy. The sad part is most of them end up with real car problems within 6 months. They just don't take care of the little things. I feel horrible knowing that I am going to drive it for 3-4 hours with that stupid light on.
thanks again.
Old Aug 6, 2009 | 09:49 AM
rebelheart's Avatar
rebelheart
Purely an emmission control issue,your vette wont run a bit differently.
Old Aug 6, 2009 | 01:21 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
DTC P0443 - Evaporative Emission Purge Solenoid Control Circuit
If thats the only DTC,,,your GOLDEN! Drive it like you stole it! Enjoy the drive home!
Bill C
Old Aug 6, 2009 | 01:56 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Is this one of the codes given if the gas cap is loose?
To need urgent advice.
