Cam and Head Package?
IMHO stick with 1 3/4 headers
Or are you just echoing what the marketing machine fed you?
Let me know if you guys see anything I should add or maybe give suggestions on the cam choice and how it will feel / sound / drive as a daily.Just some overall input on this setup would be nice!
Thanks!
* LG C5 1 3/4" Street Series Long Tube Headers w/Catted X-Pipe
* Trickflow 220cc As Cast Cylinder Heads (not CNC but Seth said only 3% airflow loss)
* Mill Heads to 59cc
* ARP Head Bolt Kit LS1
* ARP Assembly Lube (1.69oz)
* GM MLS Head Gaskets 5.7 LS1
* Yella Terra Ultralite Rockers, LS1, 1.7 Ratio Non-Adjustable
* GM LS7 Lifters
* FAST 36# Injectors (LS1,LS6)
* Comp Cams Camshaft (230/236 .612/.607 112 LSA)
* Comp Cams Pushrod Length Checker
* Comp Cams Magnum Pushrods 7.xxx
* SLP 25% Underdrive Pulley, Corvette 97-08
* Serpentine Belt for C5 & C6, using SLP Pulley
* FAST Intake - GM LSX 92mm
* GM LS2 90mm Throttle Body
* Harness TB - Adapts GM LS1 harness to GM LS2 throttle body
* FAST Intake Port Seals (Set of 8)
* GM Front Cover Gasket
* GM Front Main Seal
* GM Water Pump Gasket
Thanks!
* GM LS7 Lifters
WOW! Great looking list! You will get alot of gas stink with that cam at idle, even with cats, just so you know. Looks like you really cut loose the wallet.
Revised valve angle helped, but the larger valve diameter took it right back.
Now whack .030" off the deck to get to 59cc, and see what happens.
I'm not saying it's a recipe for disaster, but it is definitely close enough to warrant checking. If I were recommending and selling such a package, I would have already done it and have some real measured data to offer.
Or, maybe I'm just confused why I recently helped a guy flycut his 61cc TFS setup with a 232/236-113 cam because he only had .040" p/v clearance. Everyone here told him it would clear easily....until install time.
Peak lift occurs when the piston is several inches down in the cylinder.
p/v clearance problems occur very near piston TDC, as the valves are just opening or closing.
I wasn't even taking gas mileage into consideration with this setup
How much mpg city / highway with this setup will I get?
Thanks for the input everyone!
When I usually do something I usually go ***** to the wall
Your setup looks like a wet dream H/C deal. I increased my mileage 2 MPG to 27 highway, AFTER my mods. The problem is in town, it's so much fun to get on it just a little bit more, the mileage really suffers.
