Ask twice,purchase once.............
Old Aug 27, 2009 | 08:52 AM
  #41
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Originally Posted by rebelheart
If you make a bit more power and it takes a bit less throttle opening to maintain that speed you will see an improvement in mpg.Was the duct and MAF relocation the cause of this? Who knows,could just as well of been the 10 degree cooler ambient temp.I am just reporting what I saw on my cars readout on a 50 mile straight line,cruise control on trip to the track. But the lack of that MAF code reappearing and the better idle quality are facts.
Were you using A/C with this 10 degree cooler temps?
Old Aug 27, 2009 | 09:41 AM
  #42
rebelheart's Avatar
rebelheart
A/c settings werent touched, but it may not have cycled on as much.It was still 85 degrees out and 90% humidity!
Old Aug 27, 2009 | 09:47 AM
  #43
Eric D's Avatar
Eric D
Bingo! You anticipated where I was going. I can believe this has more of an affect then anything you did in front of the throttle plate. Other less obvious factors can be prevailing winds.
Old Aug 27, 2009 | 08:15 PM
  #44
rebelheart's Avatar
rebelheart
Keeping an eye on it around town now as the temps have climbed back into the normal mid 90's,time will tell.An engine is merely an air pump,if you improve flow and the computer can adjust for it,HP and MPG can be better.
Old Aug 31, 2009 | 11:03 AM
  #45
JropTop's Avatar
JropTop
Originally Posted by tstar
This is cool, I'm learning alot more about the role the MAF plays in the bigger picture. I know we're digressing from the OP's original question and I hope he doesn't mind....
If I'm understanding all this great info correctly... relocating the MAF MAY change it's input to the PCM and (technically) may reflect a more accurate reading of the actual laminar airflow hitting the TB. Assuming the airstream had a chance to settle down while traversing the bridge/coupler... Note: I think this may be more accurate for people using the twin cone assemblies.
Now this new signal may not be accurate due to the static translation table stored in the PCM right? This is where I was getting confused... I thought that table was dynamic, in other words would eventually be adjusted to account for the changes in the upstream O2 sensors outputs, as an example...
I find it interesting that the tables are different for different vehicles... Airmass is airmass after all no matter what motor it's being sucked into. I suppose it's another area that can be tweaked for tuning purposes though...
Thinking more about this, it might make more sense to relocate the temp sensor closer to the TB to take into account heat soak from the engine... I wonder what THAT would screw up????
Tim
Well,heres the verdict,I installed the Vararam power duct today with the relocation of the MAF sensor near the throttle body,no issues whats so ever,easy install,all works and runs normal!
Old Aug 31, 2009 | 11:30 AM
  #46
Eric D's Avatar
Eric D
Wow! That must be disappointing! I thought the whole point was to make it run better.
Old Aug 31, 2009 | 05:06 PM
  #47
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
It might at WOT... Or in a bad cross wind!
Heck it takes 25 HP for my butt meter to notice a difference... And NO it doesn't need recalibrated!
Tim
Old Aug 31, 2009 | 05:50 PM
  #48
JropTop's Avatar
JropTop
Actually it goes faster backwards now!
Old Aug 31, 2009 | 06:07 PM
  #49
tstar's Avatar
tstar
Where the hell did you test that at??????
Old Aug 31, 2009 | 06:19 PM
  #50
ncvettes's Avatar
ncvettes
On the back road...
Old Aug 31, 2009 | 06:21 PM
  #51
tstar's Avatar
tstar
Old Aug 31, 2009 | 06:54 PM
  #52
JropTop's Avatar
JropTop
Originally Posted by ncvettes
On the back road...
Come on Tim,your slackin! lmaooooooooo
I bet you im the only one who can get bug splats on my rear bumper!!!!!!!!!!!!!!!
Old Nov 17, 2009 | 03:05 PM
  #53
aweil's Avatar
aweil
Your engine is pulling a constant vacuum,it has no "out going" pulses! If it does you have a problem like a leaking intake valve.
Hi Miss Information. Nice to meet you. My engine has a problem called an AFTERMARKET CAMSHAFT which causes intake reversion due to the overlap.
