no HP gain
Old Aug 30, 2009 | 08:45 AM
canada99vette's Avatar
canada99vette
Default no HP gain
Hello, hoping somebody could shed some light on my issue. Last year at Carlisle I dynod 371 hp with the following mods. LS1 intake, stock heads,VRX3 cam, stock TB, LT headers no cats and borla exhaust.
This year I added a BBK intake and 80mm TB as well as a set of MTI racing stage 2E heads, high flow cats. I dynod on the same dyno at Carlisle and got 369 HP. I didnt gain a thing from my added mods. Now my tune is finished yet, could that be it? I also logged the dyno runs and could see KR at the upper rpms. Also last year my car was still pulling at 6800 rpm, this year it was dropping off at 6400. I can send the logs and dyno info if somebody would like to take a look at it for me. Thanks, Dan
Old Aug 30, 2009 | 10:33 AM
OutKlast's Avatar
OutKlast
Hard to say for sure because dyno power varies a lot based on temps, humidity, etc. You could drive around town and dyno on 4 machines and get 4 different readouts.
Old Aug 30, 2009 | 12:27 PM
David426's Avatar
David426
Most of us think putting a car on the dyno is like getting on a scale and weighing something. You get a number and thats it... There are way to many variables with a dyno.. I just saw a post on here and the guy was making 350rwhp and 385rwtq on a basically stock LS1
Old Aug 30, 2009 | 02:30 PM
GETOPLES's Avatar
GETOPLES
I agree that different ambiant conditions will affect the dyno...but this is saying that he gained 0 hp....not sure about that.
Old Aug 30, 2009 | 03:15 PM
AU N EGL's Avatar
AU N EGL
could be the BBK intake. There have been a few tests published and none showed any gains over the LS6 intake.
BBK did lots of improvements, but have not seen the results.
Old Aug 31, 2009 | 12:28 AM
canada99vette
I would have thought that with a set of aftermarket heads, intake and TB I would have seen a little bit of increase in power. What about the cats I had installed, would that cause the 0 power increase?
Old Aug 31, 2009 | 12:37 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
A proper tune can definitely pick you up power. Don't be disappointed until you know it's tuned correcly. I was running a little lean at the track the other day. I added a little fuel and timing to the tune and picked up 3mph. Did they put a wideband on the car while dynoing it? If so, what was your air fuel ratio?
Old Aug 31, 2009 | 12:58 AM
canada99vette
the air/fuel at 4000 was 13.77. at 5000 it was 13.41. 6000 it was 13.34 at 6700 it was 12.56. I can scan the dyno sheet if it would help. I also logged the 2 runs with HPtuners. Thanks for the help.
Old Aug 31, 2009 | 05:19 AM
vettenuts's Avatar
vettenuts
I am somewhat bothered by your statement that the power fell off early. Depending on what the curve actually looks like, there could be some valve train instability.
Old Aug 31, 2009 | 07:45 AM
AU N EGL's Avatar
AU N EGL
yes with the right combo and Tune. High flow cats have no effect, but also dont detract
I noticed you said you made two passes with HP Tuners. Are you an experienced programmer or tuner with HPTuners? If not find an expert with HPTuners and let them do their magic.
Just because we can buy a copy of HPTuners or EFILive, does not mean we know how to use it in 2 hours of playing with it.
Old Aug 31, 2009 | 08:44 AM
canada99vette
the tune it it right now is just a starting tune for it to run alright with the mods I have. I have an experienced tuner that will be doing the full tune for me. I logged the 2 passes. I hear you about buying the tuning software and being able to tune in 2 hours I have owned HPtuners for a year and am still learning. just hooked up my wideband in my car last week.
Old Aug 31, 2009 | 08:56 AM
dankhts's Avatar
dankhts
prob needs to be dyno tuned properly with wide band - my set up is small VRX1 cam, Lingenfelter ported heads, long tubes, high flow cats, UD pully, Yella Terra rockers, cat back, CA intake, etc, with mods before tune - 378 hp, after tune - 409.97.... had to fiddle with the tune a time or two afterwards, but now drives like stock...screams pretty good when the pedal is pushed though...
Old Aug 31, 2009 | 09:18 AM
canada99vette
awesome, thats what I want to hear
Thanks guys.
Old Aug 31, 2009 | 10:19 AM
TurboBerserker's Avatar
TurboBerserker
If you are getting KR, the OS is pulling timing. It does you no good to compare untuned dyno numbers to tuned dyno numbers.
Old Aug 31, 2009 | 01:46 PM
Corvettes of Dallas - Parts's Avatar
0Corvettes of Dallas - Parts
Former Vendor
There are so many varations of "WHY" dyno numbers can vary or decrease etc.
I would check into your tune and go from there!
How does it drive?
-Adam
To no HP gain
