cam problem help
Old Sep 5, 2009 | 12:11 PM
Gitusum's Avatar
Gitusum
Default cam problem help
i think i wiped out a cam lobe in my car and its a texas speed t2 112 cam and i liked the lope and good hp with it but it seemed a lil low on the torque end so im looking for a cam that is somewhere in the same specs as the t2 cam that produces more torque. any good cams that produce more torque around the specs of this cam? the specs on the t2 cam i have now is 232/234 595 598 112
Old Sep 5, 2009 | 05:01 PM
Gitusum's Avatar
Gitusum
someone! anyone!
Old Sep 6, 2009 | 01:37 PM
Gitusum's Avatar
Gitusum
Old Sep 7, 2009 | 12:22 PM
Gitusum's Avatar
Gitusum
Old Sep 7, 2009 | 01:01 PM
AU N EGL's Avatar
AU N EGL
How much torque do you have and how much do you want?
Cams around the same specs will produce close to the same numbers. a little +/- and little up or down on the curve
Comp cams
228/232 585/595 110
224/230 581/588 114
230/230 580/580 112
232/234 595/598 112 XER281HR
Old Sep 7, 2009 | 01:12 PM
Gitusum's Avatar
Gitusum
right now i have 429rwhp and 376 torque which i feel is a lil low
Old Sep 7, 2009 | 01:40 PM
TurboBerserker's Avatar
TurboBerserker
If you want more torque you need to go to a smaller duration (to shift the power down in the power band), tighter LSA, or advance the cam (either by getting more advance ground in or by cam timing). Each will have it's trade offs.
Smaller duration means less total power, less chop at idle (probably). The trade off is that you will make better low and midrange torque but will see lower peak numbers.
Tighter LSA means a narrower power band, higher cylinder pressures, decreased ptv, rougher idle, increased overlap, increased cranking compression (and dynamic compression). The trade off is that you move the torque band lower in the rpm range.
More advance means decreased ptv on the intake (but increased ptv on the exhaust). The trade off is that you build more low end torque at the expense of high end torque.
Old Sep 7, 2009 | 01:42 PM
TurboBerserker
Are your performance goals not being met or something? Dyno numbers are meaningless except as a way to judge the effectiveness of a new change or as a tuning tool.
Old Sep 7, 2009 | 02:06 PM
Gitusum's Avatar
Gitusum
well it just seemed a lil low on the torque end of it but the hp was fine. i feel like if i could get a cam that pulled a lil better seeing how i think i wiped out a cam lope i think but will not know for sure til tomorrow when the motor ets torn down what better time than the present to try a different cam that may up the numbers and may give me better performance
Old Sep 7, 2009 | 03:21 PM
MattB's Avatar
MattB
How the heck would you damage a cam? Isn't that one of the strongest pieces in a valve train? I'd be thinking push rod or valve being bent or a spring break long before I'd suspect a cam issue. But, what do I know, I'm no expert.
It looks like you have the stock gear ratio, I'd be looking at gears before I'd look at a different cam. Unless there is something wrong with your cam or its not very suited to your application. Even then I'd be looking at gears, it looks like your into drag racing and if so the 4.10's may be good for you. Again, I'm no expert and I don't drag race, but maybe something to think about.
Old Sep 7, 2009 | 03:26 PM
Gitusum's Avatar
Gitusum
i dont drag race but i do romp around on the streets some lol. all i know is the car is knocking and they took the valve covers off and all the rockers push rods springs were fine. the 1st rocker on the passenger side front has some crazy play in it and they took a snap on camera and stuck it down the head and there is a couple gouges from the valve hitting the piston but the piston looked ok and they think its in the valve train maybe a lifter or a wiped out cam lobe or both. i will not know til tomorrow when they get the head off and look further
Old Sep 7, 2009 | 05:02 PM
MattB's Avatar
MattB
Good luck with it. Sounds like at least a bent valve. But why it bent is the question. Have you tried ls1tech.com?
Old Sep 7, 2009 | 05:21 PM
sami85L98's Avatar
sami85L98
I still have 21stcenturymusclecars cam 228/232 .590/.595 113 LSA. BNIB LMK if $375 shipped to u with tracking number.
Old Sep 7, 2009 | 05:35 PM
Gitusum's Avatar
Gitusum
i will know tomorrow dor sure once its down
Old Sep 7, 2009 | 06:39 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
I doubt the cam lobe being wiped. Did you or someone else have a miss shift and over rev the engine? That could have caused the valves to float and allow the piston contact. Chances are that other cylinders have valves that contacted as well. Make sure to check all of them.
On the LSx engines the only times I've seen cam lobes damaged is if the lifter gets 90 degs to the path of normal rotation, caused by broken lifter tray, or miss heat treated cam lobes. If this happened, you will have metal in the oil and a slight chance of main and connecting rod bearing damage from the metal.
Hope the best for ya!
Old Sep 7, 2009 | 06:47 PM
Gitusum's Avatar
Gitusum
i didnt over rev it and its a automatic. i did nail the pedal hard tho but never hit the rev limit thru the shifts
Old Sep 7, 2009 | 10:27 PM
Randy@RaginRacin's Avatar
Randy@RaginRacin
Supporting Vendor
Our 224/232 will produce gobs of torque. SO does our RR230.
To cam problem help
Old Sep 8, 2009 | 08:37 AM
LightFighter_GXP's Avatar
LightFighter_GXP
sounds like they didn't check the clearances when they did your install... thats pretty important... cost 300-400 to notche your pistons vs doing a total teardown and fixing broken valve train parts
Old Sep 9, 2009 | 10:09 PM
Gitusum's Avatar
Gitusum
well i found out what happened to the motor. the roller came off the bottom of the lifter and messed up the cam and unfortunately the block as the lifter got spread and jammed in the block and ruined the block.
Old Sep 9, 2009 | 10:14 PM
whiteboy572ci's Avatar
whiteboy572ci
Futral F13 on a 112 will work awesome! 230/232 .59x lift. It typically makes good torque and hp. I have a friend that made 444rwhp and 426rwtq.
