Voltage question
Old Sep 9, 2009 | 06:04 PM
CH.CRAFT's Avatar
CH.CRAFT
Default Voltage question
DO ANY OF YOU GUYS MONITOR THE VOLTAGE ON YOUR VETTE ? THE REASON I ASK IS THAT AFTER REPLACING THE BATTERY, (WITH A SEARS AGM) ON MY 2004 ZO6, I STARTED TO WATCH THE DIC CLOSELY. I READS "MOST OF THE TIME" 13.8 TO 14.2, AND I DON'T REMEMBER WHAT IT READ BEFORE THE BATTERY CHANGE, I THOUGHT IT WAS A LITTLE LOWER BUT NOT SURE. THANKS IN ADVANCE.
Old Sep 9, 2009 | 06:42 PM
Bakersfield's Avatar
Bakersfield
That voltage is about right. The reason it is a little over 12 volts is because the alternator is re-charging the battery. Don't worry, everything is fine.
Old Sep 9, 2009 | 06:53 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
FIRST OFF,,,,DON'T SHOUT!!!
Next,,,that DIC meter and IPC volt meter doesn't really read BATTERY VOLTAGE. It reads voltage in the circuit. That voltage goes thru the ignition switch.
Read the TRUE battery voltage at the battery terminals with the enging running and off, and compare it to the other meters in the car.
If you read the back of the alternator (BATT Terminal under the black rubber boot) with the engine running,, it may even be higher than the actual battery voltage (hopefully not by much) )
So,,,before you get really concerned, take a couple readings and report back the results.
BC
Old Sep 9, 2009 | 09:31 PM
bobby777's Avatar
bobby777
After the car sits over night the battery at the terminals should read 12.70 -12.80 volts==good to go
Old Sep 9, 2009 | 09:54 PM
CH.CRAFT's Avatar
CH.CRAFT
[QUOTE=Bill Curlee;1571437928]FIRST OFF,,,,DON'T SHOUT!!!
So,,,before you get really concerned, take a couple readings and report back the results. I'LL CHECK IT AS SOON AS I CAN, BILL I ALSO INSTALLED THE RACETRONIX FUEL PUMP WIRING HARNESS THAT CONNECTS TO THE REAR OF THE ALTERNATOR TO FEED THE FUEL PUMP AFTER REMOVING THE MAGNAVOLT "BOOST A PUMP" THAT CAME WITH THE MAGGIE. I STARTED HAVING PROBLEMS WITH FUEL PRESSURE WHICH APPEARED TO BE AREATION WHEN BLEEDING FUEL FROM THE RAIL. HOW MUCH VOLTAGE IS ACCEPTABLE FOR THE 2003 1/2-UP FUEL PUMP ? THANKS FOR THE HELP.
Old Sep 10, 2009 | 01:09 PM
CH.CRAFT's Avatar
CH.CRAFT
i checked the voltage this am, at the battery prior to start was 12.7, after start 14.3, at the alternator 14.7, the dic was 14.2.
Old Sep 10, 2009 | 02:28 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Looks Ok to me. 14.2+ is good!!
Old Sep 10, 2009 | 03:15 PM
CH.CRAFT's Avatar
CH.CRAFT
thanks, any insight on the fuel pump with the racetronix wuiring harness ?
To Voltage question
