Looking for a Motor Mount DIY
If you take a look at molson’s post right after your response, “you can notice a difference in power delivery”. The fact of the matter, it will increase the amount of vibration into the vehicle with no benefit. If you took a ¼ mile run with stock engine mounts and then replaced them with poly mounts and ran the ¼ mile again you would see zero benefit in track times. I see a number of folks that will make statements like this about Corvettes. Unlike the “F body” mount changes on the Corvette will not gain you much if anything at all.
And I agree with the difference being null or at the most very minimal.
I only see it as a "fun factor" for my street warrior. lol. I love the rattle feel. lol.
Downside is, a good set of poly mounts will cost you. I use VBP stuff, and the motor and rear diff mounts will set you back almost $500 total with shipping.
Dope
They come with a lifetime warranty
With my old mounts I could shake the engine back and forth with my hand.
Perhaps I notice a bigger difference because my stock ones could have been worn out.
"The "torque tube" transmits this force by directly coupling the axle differential to the transmission and therefore propels the car forward by pushing on the engine/transmission and then through the engine mounts to the car frame. In contrast, the Hotchkiss drive has the traction forces transmitted to the car frame by using other suspension components such as leaf springs or trailing arms."
All of the force of the motor that gets translated into motion goes through the motor mounts. The rotational force, on the other hand, stays the same as in a Hotchkiss drive; the motor will flex when you rev it, responding to Newton's Third Law of Motion that for every action there is an equal and opposite reaction. The motor internals are driving the drive shaft in the torque tube in one direction, so the motor's externals will end up trying to drive in the other direction. You mount the motor to the frame to counter this motion. If it wasn't for the motor mounts absorbing the rotational force of the motor and transmitting them to the frame, the first time you stepped on the go pedal the motor would just twist in place at RPM (what an interesting picture that provides).
http://www.pfadtracing.com/catalog/p...products_id/99
