A friend asked me if anyone knew if there is a way to bypass a sensor on the shocks???I think it's a 99 and the shocks are shot and the guy wants to put regular shocks on in place of the magnetic shocks?Any one???CJ.
Remove the shocks and ride control computer. Have the F45 option removed from the computer with a TechII device. Dealers and many tuners will have one.
Purchase and install shock simulators (they plug into the harness at each wheel).
Make your own simulators from large resistors. Instructions can be found with a thorough search.
Cut the wire from the shock and splice in a 10 watt 10 ohm resistor in between the two wires. Wrap them up good and tie them to the wheel speed sensor wires to keep them out of the wheels.
