Looking for input. I bought a used 2002 coupe with about 25K on the ticker about a year ago. Seems to be pretty stock in appearance (no headers or anything obvious). I added a cat back exhaust and did the "Zip-Tie" CAI mod. Now reading various specs my expectation was to see less than 350 HP at the rear wheel.
This is were it gets interesting. I ran a 376 HP at the rear and 390 ft lbs torque today. A few guys there were commenting that this particular Dyno machine was showing lower than others they had been on by about 5 horses. I ran these numbers consistantly on multiple runs. Call me crazy but I am sure that a Cat-back exhaust didn't give me these numbers.
Is there any way to determine what may have been done to the car from the previous owner?
Safe input is that dyno is reading very very high. Your numbers should be closer to 310rwhp or so.
Originally Posted by vetfeva2
Looking for input. I bought a used 2002 coupe with about 25K on the ticker about a year ago. Seems to be pretty stock in appearance (no headers or anything obvious). I added a cat back exhaust and did the "Zip-Tie" mod. Now reading various specs my expectation was to see less than 350 HP at the rear wheel.
They were just about right. A few guys thought the dyno was low but for the most part the other guys that said they were bone stock ran exactly what was expected per specs.
Originally Posted by vettenuts
Does the exhaust have any little pop to it that would indicate a small cam?
I have quite a bit of popping in my exhaust (which I like actually) when decel. I noticed it was more that other vettes I run with but figured it was normal with my cay back exhaust. That could indicate the possibilty of a cam?
Were you at the dyno with buddies? Are you sure one of them didn't tip the dyno operator a few bucks to add some virtual hp? It would be the first time this has happened.
Could you open the hood, and look at the bottom front of the right head, and tell us the 3 digit casting #?
You might have to pop up the rail cover to see it, but it should otherwise be visible.
If you find there is no number there at all, look at the front surface of that same head (right behind the tensioner), and see if there is any logo machined on that surface
No, primarily at idle. Will give an indication of a larger cam overlap.
It read 241. Not to sound like an idiot but does this tell me anything? I have a 2000 also and it had no number at all in either place. Is that right?
I only knew one person there well (Dan, the owner of VetteWorks Online), the others I pretty much met there. That would be a dirty trick especially since I told the guy doing the runs from Jet City Tuning that I wanted to get a baseline before I put headers on.
Cam only kit in the car..There shouldn't be any popping with a stock cam. The best way to tell would be to pull the valve covers and check for new springs.
Really? Because I have a lot of pop/crackle on decel as well. I'd assumed it was typical of my B&B Bullets. It was lessened a tad when I put in a Corsa X-pipe, but it's still very noticeable.
Those #'s would suggest an LS6 cam hiding out in there That is about exactly what my hp #'s were with just cat back, CAI, and tune. However I did not get a tq # that high. I don't know about a stock LS1(I don't think so), but an LS6 will not "sound" like a cam but at idle the car will give just a little tiny bit of a shake to it, you can feel it just sitting in the car and paying close attention.
