Bad Harmonic Balancer..Need help
Old Nov 2, 2009 | 10:27 PM
frc99c5's Avatar
frc99c5
Default Bad Harmonic Balancer..Need help
So today i noticed a burnt oil smell coming from my car.. i lifted the rear end up..saw no oil leaks at all.. then i figured out my jack wouldnt fit under the front so i started the engine to see if i could see anything anyway...
I saw no oil leaks but i did notice a very slight wobble in the harmonic balancer pulley.. I believe the oil is coming through the bad seal..
Is it better to buy OEM or buy an upgraded pulley? if so which?
ANd how hard is this job to do?
Old Nov 2, 2009 | 10:41 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
Don't waste your time with another OEM balancer pulley - I had them fail on me too. You want to buy a Powerbond 10% UD pulley. The quality is excellent, reasonable price and will not fail you. I am very happy with mine and I push my vette to the limits on the road courses. Good luck.
Old Nov 3, 2009 | 01:38 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The exact same thing happened to me. I let my son drive my ZO6 for 2 weeks upon his return from 15 months in Iraq. When I got it back the ENTIRE bottom of the car was oil soaked.
I was ready to beat some ****. Then I figured out where the oil was coming from:
Bad timing Cover seal and damper sealing surface. Nothing that he did to cause it to fail!
Get ya a POWER BOND damper!
You will NOT be sorry! Very quality piece that will withstand a beating!
I love mine!!
BC
Old Nov 3, 2009 | 07:46 AM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Let me know if you have any questions or if you decide to so an under drive pulley we always have them in stock.
Old Nov 3, 2009 | 08:25 PM
road dog's Avatar
road dog
power bond fluiddapner on mine I love it
Old Nov 3, 2009 | 10:55 PM
frc99c5's Avatar
frc99c5
taking it to a mechanic here in town whos worked on vettes for years. No way in hell would i try this project by myself! quote was $430 with everything... reasonable plus ill feel better! there putting back an oem pulley but its warrantied.. ill deal with it again down the road if i have to..
Thanks again everyone for the advice and feedback, you rule
ttyl
Old Nov 4, 2009 | 10:01 PM
Meech's Avatar
Meech
I have some wobble as well but no burnt oil smell. Is a little wobble normal? Had a squeak but replaced the tensioner pulley and threw on a gatorback belt. No squeaks now that I can hear but still a little wobble??
Old Nov 4, 2009 | 10:52 PM
Slow Z06's Avatar
Slow Z06
if it wobbles, get rid of it. I got a power bond ud pulley, used here. If you get in houston Ill sell it cheap. I got a new stock ratio pulley for my new build
To Bad Harmonic Balancer..Need help
