Help needed after new clutch install....
As to why the vibration goes away, remember that you're not feeling the vibration directly, you're feeling it after it's gone through the rubber mounts. The purpose of those mounts is to absorb vibrations, and when the mounts ability is overwhelmed you feel what comes through.
Have a good one,
Mike
Am I reading this wrong,or what?
The harmonic balancer,yes,but according to what I'm reading ,NEW flywheel,NO.
So it looks to me like the install was done correctly,and the vibration is being caused by an imbalance in one of the components of the new assembly-maybe the SLP flywheel doesn't match up,balance-wise with the Spec pressure plate?
Doesn't seem like it should matter,but apparently in this instance,it does...
This subject has come up and was debated before, run a search on "match balancing".
I’ve seen so many people have issues with the install of this clutch that it makes me Ill.
Some of the issues have been installation mistakes some not. I need to get this pre measurement thing laid out so that I can visualize how to do it correctly. Measure twice, install ONCE! I already purchased the TICK Master and all the other new stuff to do this correctly.
When I do my clutch,,, I’m going MARK EVERYTHING on the OEM ZO6 clutch before I remove it. Then I’m going to take the OLD assy and NEW SPEC assy to the machine shop and have the balance checked on each clutch assy. Depending on what this show me, I will have to figure out what to do.
Right now, I have zero vibrations on my OEM Clutch/engine. If the old assy is significantly out of balance, I guess I will have to have the spec fly wheel off set to that grammage.
If there are balance pins in the old fly wheel, I can mark where they would have gone in new fly wheel and work with that known value if there are issues after install.
Ksths2
I would go back under the car and do some additional clutch air gap measurements and make sure that you measured the CURRENT air gap measurement correctly. Looks like the air gap is excessive. Getting an accurate measurement on TWO disks can be difficult.
Get a set of LONG feeler gages and use those to check the clearance across a large area of the pad and make sure that you take all the clearance out between the pad and pressure plate and fly wheel. Press the clutch peddle lightly and see if it engagement point feels different with the feelers installed. Then go back and see if you can get more feeler gage in the air gap.
IF,,,the air gap is not excessive, it is possible that you still have air in the master or slave as strange as that sounds. Some people have had luck applying a vacuum on the clutch reservoir and been able to pull additional air out. Might try that.
I would also take the clutch assy to the machine shop and check the balance. Your most likely going to find out that its out of balance and that’s your issue. Do you have your old clutch pressure plate/flywheel assy that you can use as a balance reference?
Only trying to help.
Bill
I'm in the middle of the Tick adj. MC install and we'll see what happens after that. I bet its the clutch assembly not balanced but i dunno. i took the inspection cover off and the clutch assembly looks beautiful with no visual problems that i can tell other than very little gap between the flywheel, clutch disk, and pp when the clutch is pushed in. aka not disengaging.... i figure worse case i'll take it all back apart and have the clutch assemlby balanced together.
On a side note, i'm trying to break-in this clutch before winter hits here in Iowa and the Spec instructions say to have 500 miles of stop/go driving..... my problem is with that is what do people do with race engines running this clutch? i mean, if you'd put 500 miles on a race engine it'd be worn out before the clutch was broke-in so are the truely 500 miles really that critical??
And one more weird question, could i break the clutch in with this vibration without causing any harm to stuff? (engine, trans, etc) Only reason i ask is as soon as its broke-in i'm taking it all back apart to put the heads/cam in etc and it'd be alot easier for me if i could wait and do it all at once?
Thanks for everyones help i really appreciate it.
i'm in the middle of taking it all back apart so i can try this idea, if it don't work i'll kill myself lol
have a good Thanksgiving!
My spec 3+ and billit flywheel was 21 grams off 6" from centerline and most of the imbalance was from the pressure plate(18 grams). It did cause a vibration like you describe. I didn't buy the clutch/flywheel as a package as my friends didn't stock it that way, but spec does balance those package units as a assembly, but I'd rather check it at the machine shop anyway. I just removed weight from the flywheel to zero balance the clutch/flywheel as a unit as my 383 is fully balanced internally.
Your approach to correct your imbalance by installing the original flywheel is one way of handling it. You could also have your machine shop friend match the new to the old if you see an advantage to using the newer flywheel.
I would like to point out, all LSx engines are designed to be internally balanced. External balance weights are corrections and not the norm. There are other engines designs that require special flywheels with built in imbalance that are part of the rotating group. Not the case in any LSx series engines.
All LSx series engines that come off the assembly line take a net zero imbalance flywheel and harmonic balancer. The flywheels may have areas of drilling that are not through holes. These drill locations are to correct the flywheel to net zero imbalance. If the engine has vibration after assembly there may be small weights added to the flywheel to correct it. The weights are various length pins with raised ribs that are tapped into one or more of the through holes drilled around the outer diameter of the flywheel just inside from the starter ring gear. These added weights are easily missed during a clutch/flywheel install if the installer is unaware of them.
I hope the best with your balance project and have a Happy Thanksgiving!!
Oh and one more thing, when i put the new clutch in the i replaced the throw out bearing with the new one that came with the clutch and it looked identical to the one i took out. the weird part is, the little bit i did drive the car trying to dianose the vibes the TOB whines like crazy when driving and the pedal out in neutral it sounds like the TOB is bad. you know how it rattles and sounds nasty...... how can this new one be like that? the stock TOB i took out was shot and didn't sound that bad.
A light weight billet steel flywheel works best and helps shave off some weight.
One other thing, i first time i installed this i put a new TOB in but it whines now and rattles when i shut it off worse than it ever did with the stock one. Should i not worry about it or put another new one in?
As for the Throw Out Bearing, it typically comes as an assembly (aka Clutch Slave) I use the stock 2004 Z06 slave in all of my installs and have not had any problems.
Not sure what slave you're using ? The slave is sprung loaded against the fingers of the pressure plate so you should not really hear any noises.
That was my solution, I hope yours turns out to be as simple.
I'm still using the stock slave
Yes the original flywheel has drilled holes around it and looks like tungsten or mallory slugs have been pressed in a few of the holes on the stock flywheel.... So my question is, why is everyone so against putting the stock resurfaced flywheel back in? i mean as long as the gap is right why would it be bad?
Pilot bearing looks beautiful and needle rollers move smoothly. Hey ARKAY, to add these washers like you mentioned you surely didn't put the entire driveline back in everytime to test this did you? If not, how did you fire your C5 up without the electrical, brakes, O2 sensors back together? I mean, didn't your car get super pissed??
