They welded a washer onto the PP, i figured they would of taken material out of the flywheel. who knows maybe it'll work.
I'm still using the stock slave
Yes the original flywheel has drilled holes around it and looks like tungsten or mallory slugs have been pressed in a few of the holes on the stock flywheel.... So my question is, why is everyone so against putting the stock resurfaced flywheel back in? i mean as long as the gap is right why would it be bad?
If you want the vibration issue fixed, put the stock flywheel back in, or have the new one matched to the old flywheel imbalance. Anything short of this and you will have the vibrtion issue once again.
Pilot bearing looks beautiful and needle rollers move smoothly. Hey ARKAY, to add these washers like you mentioned you surely didn't put the entire driveline back in everytime to test this did you? If not, how did you fire your C5 up without the electrical, brakes, O2 sensors back together? I mean, didn't your car get super pissed??
Heh, nah, it's done with the whole thing together. Just drop the inspection cover, number the bolts by turning the flywheel by hand, then put a washer under #1 and start it and check, if not an improvement take out #1 and move to #2, etc. I did it on jackstands. Just gotta be careful of the exhaust pipes. They do get hot, but you only need to start it and run it for a few seconds each time to tell.
I'm assuming the shop that did it for me the first time (yes this happened to 2 clutches for me) used the same approach, but they had the luxury of doing it on a lift.
I 100% agree with you Eric D about the stock flywheel but what about the 14 grams they added now to the PP? My thoughts are both flywheels should be 0 balance so it shouldn't matter at all? or am i wrong?
ARKAY, that makes sense but i can't get my stupid inspection cover off with the headers on.....but I'd just leave the inspection cover off till i got the vibes fixed then take the headers off to put the cover on...... thanks for the help guys, i'll let you know the out come
You need to know if the weight they added was to bring the PP to zero imbalance or the new flywheel. Without knowing this you are taking a chance of having more vibration issues. Knowing the original flywheel had added mass means your engine has internal imbalance that needs to be corrected externally at the flywheel. If you find out for sure that the mass was added to correct the imbalance of the new pressure plate, then installing your original flywheel or having the new flywheel matched to the original imbalance flywheel should take care of any vibration issue.
If your OEM fly wheel has weights to OFF SET it to "XYZ" grams off ZERO balance from factory zero balance to correct for some internal engine balance issues and you install a new ZERO balance fly wheel,,,, the engine will be off XYZ grams.
Have your ZERO vibration OEM flywheel balanced checked and then have your NEW flywheel off set to the OEM flywheel imbalance to retain your ZERO IMBALANCE drive train
i understand, i was wondering if the weight they added to the PP was to get it to zero or to compensate for the SLP flywheel that's supposed to be at zero to begin with.
If your OEM fly wheel had ZERO vibrations, you need to take the OEM fly wheel and the new flywheel to the machine shop and have the NEW flywheel OFF SET to the same off balance the OEM fly wheel is. Then you wont have a vibration. GM uses pins to finial balance the LS engines. If yours had pins and the new flywheel does not have holes for pins, the machine shop will have to remove material to off set balance it.
BC
Wouldn't he have to take the entire assembly with the pressure plate indexed as it was originally to get the #'s correct? I would expect some of that weight on the flywheel to be correcting any imbalance in the pressure plate assembly as well.
From what I understand and have gathered, the pressure plate and disk, SHOULD be zero balanced.
That way,,,once the mis balance inside the reciprocating assembly inside the block is corrected by the off balanced flywheel, any pressure plate that is zero balanced can be installed and not cause an issue.
I feel your pain I had a big issue with balance on the LS6 unit I put into my car I had vibrations from 700RPM and up , I ended up using my original flywheel just had it resurfaced. and that fixed the issue... My flywheel had the added weights what a PIA!! After all troubleshooting and efforts to balance the new assembly was said and done I ended up pulling the clutch assembly 5 times
I replaced my clutch assy and I balanced the flywheel/clutch to zero balance even though manufacturer said it was balanced I checked it anyway.
I did NOT put any weights back on from stock fw or match the balance to the old flywheel as this does not need to be done and I have ZERO vibration issues.
If there are vibration issues then the aftermarket assy isnt zero balanced correctly.
BC
Any good manufacturer of clutch assemblies should have their products balanced to zero imbalance. If your original flywheel has correction weights installed from GM, you better match this imbalance in the replacement flywheel if you want to avoid vibrations. The only exception to this is if any internal recpicating parts have also been replaced or the engine had a vibration prior to the flywheel change.
I ended up installing the SLP flywheel and the Spec 3+ after it was balanced, iam truely blown away it was only 14 grams off but made that much of a vibration @ 1800-3000rpms.....Anyway, didn't do anything differenet on the install and its as simple as the vibes are gone now.
Now i can start on the heads and cam install.......hopefully i don't run into as much problems lol
I put a manual tranny on LS1 which was originally equipped with automatic. If that's not enough thrill, I took the crank pulley off without marking it's position on crank..
Now I'm putting new LS7 clutch&flywheel and ATI supercharger pulley on this engine and I'm a little nervous after reading this thread. Yesterday I didn't know too much of LS engines, now I know just too much to sleep well.
