Question on LS1 HP and Torque
Old Nov 11, 2009 | 10:44 PM
wolfman04's Avatar
wolfman04
Default Question on LS1 HP and Torque
In the Owners Manual on page 5-100 it has Hp 350 @ 5200 RPM and Torque 360 lb ft @4000 RPM is this at the fly wheel.
Old Nov 11, 2009 | 10:45 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
Yeah. Flywheel.
Old Nov 11, 2009 | 10:55 PM
wolfman04's Avatar
wolfman04
Originally Posted by clayton1
Yeah. Flywheel.
What is it at rear wheels on stock LS1
Old Nov 11, 2009 | 11:20 PM
Boulty1961's Avatar
Boulty1961
Originally Posted by wolfman04
Only the Dyno knows for sure……….
Old Nov 12, 2009 | 01:48 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
GM answered the DYNO question way back when Ford failed to produce the fly wheel results that it represented by actual FLYWHEEL Dyno HP/TQ figures. There are NUMEOUS GM and C5 owner certified dyno result figures on a STOCK C5 LS engine output results.
Spend the $50-$75 DYNO Fee and base line your STOCK RWHP results. If you make any significant MODs younwill be able to actually see the Net gain from YOUR base line.
Old Nov 12, 2009 | 01:21 PM
wolfman04's Avatar
wolfman04
That's the problem I didn't have a base line done before I had LT headers and cold air intake and BB PRT installed . Had car DYNO tuned on Monday and Throttle Body Ported now at RWHP is 325 Max Torque 333, that why I was trying to get stock numbers. Vette is 2004 A4 315 Rear
Old Nov 12, 2009 | 03:31 PM
65 Drivr's Avatar
65 Drivr
Default Rough #'s
If I remember right, I read here a couple of weeks ago...
For a M6 (manual trans) car multiply the GM listed HP by .85 and you should roughly have the rear wheel HP.
For an A4 (automatic trans) car multiply by .80
So 350 at the GM# is 297.5 at the reer wheels for an M6 car and 280 for an A4 car.
Please feel free to chime in..
Old Nov 12, 2009 | 04:41 PM
bogspores's Avatar
bogspores
Great question and answers! After buying a GeTech Pro G-meter and then seeing what it reported as my RWHP, I was really shocked!...not even close to the 350 shown in the specs....but I figured the original 350 was flywheel (it HAD to be since my GeTech showed 267 hp!)
Old Nov 12, 2009 | 06:15 PM
ILM-Express's Avatar
ILM-Express
MFIC
With shorties I'm getting 316 at the rear wheels not bad for a A4 99 that started with 345 flywheel
Old Nov 13, 2009 | 02:31 PM
wolfman04's Avatar
wolfman04
Thanks 65 Drivr that's what I was looking for.
Old Nov 14, 2009 | 07:52 AM
AU N EGL's Avatar
AU N EGL
Were not most stock A4s just under 300 rwhp ? 290-295 rwhp ?
and M6s just over 300 rwhp at 302 -305 rwhp?
Old Nov 14, 2009 | 08:01 AM
David426's Avatar
David426
Thats it... As Bill Curlee said,, you really need a baseline.. As I have said many many times. Dyno numbers vary.. I've seen them from 270rwhp on a mustang dyno to 345rwhp on a dynojet
Old Nov 14, 2009 | 10:58 AM
wolfman04's Avatar
wolfman04
This was done on Dynojet (Dynojet Performance Evaluation Program)
Dynojet Winpep 7
Old Nov 15, 2009 | 01:22 AM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi wolfman -
Normally around 295-305 rwhp bone stock.
best regards -
mqqn
To Question on LS1 HP and Torque
