pulleys
Old Nov 29, 2009 | 04:36 PM
retiredalaskan's Avatar
retiredalaskan
Default pulleys
Has anyone tried to rebuild the tension or ldler pulley, by replacing the bearings . i have a 2003 c5 a4 thanks
Old Nov 29, 2009 | 05:34 PM
corvette430hp's Avatar
corvette430hp
i think the pullies are only about $20-$30 bucks, so most just buy new and throw on.
Old Nov 30, 2009 | 06:23 AM
VET-005's Avatar
VET-005
I have changed bearings before in the Metal idler pully. Very easy bearing cost about $5. As for the plastic pullies these are not servicible and need to be replaced.
Old Nov 30, 2009 | 11:55 PM
MTPZ06's Avatar
MTPZ06
I recently saw a thread by guy that said he picked one up for about $20 (or less) from NAPA, and the pulley actually was an improved design over the OEM since it had a high lip on the edge that will reduce the likelihood of throwing a belt at high rpms.
Old Dec 1, 2009 | 05:58 AM
vettenuts's Avatar
vettenuts
I tried it once on my Pontiac which was a similar design. The pulley broke when I tried to get it apart (it was brittle from heat, time, etc.) so I took the bearing back and bought a new tensioner. Not sure its worth the few dollars saved.
Old Dec 1, 2009 | 01:14 PM
retiredalaskan
thanks it was just a thought...
To pulleys
