Billet Jacking Pucks
Old Mar 1, 2002 | 08:18 PM
vettenuts's Avatar
vettenuts
Default Billet Jacking Pucks
Was just snooping around in the Mall and found some billet aluminum jacking pucks. Anyone got a set of these? How is the quality and how do they fit? I have the hockey puck set but I think these might be better to put on for when someone doesn't have a set.
Old Mar 1, 2002 | 10:17 PM
Oldvetter's Avatar
Oldvetter
Default Re: Billet Jacking Pucks (vettenuts)
I bought 4 from ZIP. I didn't like idea of the rubber ones, worried about deformation.
They work great. Used them both to jack up and also to place jack stands on. You just twist them 180 degrees and they "lock in", easy to get out also.
Old Mar 2, 2002 | 12:16 AM
Along4theRide's Avatar
Along4theRide
CF Old Timer
St. Jude Donor '14-'15-'16
I followed the instructions on 97Vette's Page and made my own... I think it cost me $9 total! :cool:
Old Mar 2, 2002 | 12:25 AM
jpvette's Avatar
jpvette
Dumb question but...I understand using them for jack stands, but do you need them to jack up car for changing one tire for instance? :confused:
Old Mar 2, 2002 | 01:26 AM
Oldvetter's Avatar
Oldvetter
Default Re: Billet Jacking Pucks (jpvette)
Rather than driving car up on wood blocks (this is always dicey, what with the tires spinning and throwing wood), i use one floor jack, on puck, to jack up car enough to get another floor jack (with a block of wood between jack and car) under center back support to jack up whole rear end.
Old Mar 2, 2002 | 01:30 AM
Oldvetter's Avatar
Oldvetter
Default Re: Billet Jacking Pucks (Along4theRide)
Hey Along4theRide,
-It was his pictures of the pucks under load, that convinced me that I should get solid aluminum ones!
-I couldn't see dropping my vette for $40 difference!
-You really do get them up in the air, it's scary enough without soft pads!
Old Mar 2, 2002 | 01:31 AM
ruking1's Avatar
ruking1
Since there are many optional and prefered places to jack up the car, the answer is yes and no. If you are jacking to say, do a tire change in an emergency situation, the chances of you getting a Corvette specialist in a tow truck operator is not very good. Even Chevrolet dealers sometimes dont have the right equipment and knowledge to jack up the Corvette properly, or even if they do, they just ignore it. I personally carry between 2 and 4 of these jacking pucks when I venture out of my garage. While it is l"ess than safe" without jack stands, in a pinch the jacking puck can hold the car up for just a tire swap. Of course the big caveat is not to be under the car when you are doing it this way, for you risk injury and possible death in the worst case, and on the equipment side, damage to body/frame/ suspension parts. So no, not a dumb question at all.
[Modified by ruking1, 9:38 PM 3/1/2002]
Old Mar 2, 2002 | 02:35 AM
Along4theRide
CF Old Timer
Default Re: Billet Jacking Pucks (Oldvetter)
Oldvetter,
I have found them to work just fine and not to deform as much as shown in the photo's ... I however rarely use them and carry them for "just in case" situations mostly. I own a lift and use that way to lift the car unless I need to remove a wheel.
:cheers:
[Modified by Along4theRide, 10:42 PM 3/1/2002]
Old Mar 2, 2002 | 01:14 PM
Oldvetter's Avatar
Oldvetter
Wow Along4the ride,
Quite a setup you've got there. His and her vette's and stacked at that !
Old Mar 2, 2002 | 05:07 PM
turboo2u's Avatar
turboo2u
Some of these pucks are actually thicker than others. The thicker ones may not work if your car has been lowered, which is the case for me. :eek:
Old Mar 3, 2002 | 01:02 AM
RDVT4ME's Avatar
RDVT4ME
Default Re: Billet Jacking Pucks (turboo2u)
Vettenuts
I have 4 billet aluminium jacking pucks from West Coast Corvette. I am interested in selling them if you are interested. I recently put on andy's rocker rails and no longer need the jacking pucks. Let me know if you are interested.
Old Mar 3, 2002 | 02:18 AM
gmblack3's Avatar
gmblack3
I looked at the ZIP site and didn't see them. Do you have the link?
Old Mar 3, 2002 | 03:57 AM
Oldvetter's Avatar
Oldvetter
Default Re: Billet Jacking Pucks (gmblack3)
Here it is:
http://store.yahoo.com/corvetteforum/19jacin.html
By the way, you turn them 90 degrees, not 180.
Old Mar 3, 2002 | 09:07 AM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Here it is:
Is that price for 1, 2 or 4 pucks? If the ad says, I didn't see it. Thanks.
Tom
Old Mar 3, 2002 | 10:41 AM
Lil Red's Avatar
Lil Red
Default Re: Billet Jacking Pucks (RDVT4ME)
Hey RDVT4ME,
i'm interested in buying your pucks if they are still available!
[Modified by Lil Red, 9:43 AM 3/3/2002]
Old Mar 3, 2002 | 10:44 AM
gmblack3's Avatar
gmblack3
Default Re: Billet Jacking Pucks (TCW)
They show 4 in the picture, I would hope so for $55.
I was thinking of making my own:
http://97vette.com/howto/liftpads/index.html
But I would add some .125 aluminum or stainless steel to the top, bottom and inbetween the hockey pucks. I do like the idea of the added height of the double pucks. Any thoughts?
Here it is:
Tom
Old Mar 3, 2002 | 11:12 AM
Orsadude2's Avatar
Orsadude2
RDVT4ME,
I also have the rocker rails. Why don't you need the pucks anymore? Can or would you place a jack on those rails? I too have serious concerns about raising my vette. :eek:
orsadude2
To Billet Jacking Pucks
Old Mar 3, 2002 | 01:08 PM
vettenuts's Avatar
vettenuts
Default Re: Billet Jacking Pucks (Orsadude2)
QUOTE]RDVT4ME,
orsadude2[/QUOTE]
Yes, guess I am curious about the same thing.[
Old Mar 3, 2002 | 01:16 PM
vettenuts's Avatar
vettenuts
Default Re: Billet Jacking Pucks (Lil Red)
Hey RDVT4ME,
Since he responded first, I think he has first dibs.
Old Mar 3, 2002 | 04:48 PM
Oldvetter's Avatar
Oldvetter
you get 4 pucks
