Cruise Control
Old Dec 18, 2009 | 11:38 PM
Tom73's Avatar
Tom73
Default Cruise Control
Lately my curise control has been disengaging on its own. Does not happen often, but will be going down the interstate on curise and all of a sudden it will disconnect. The other day it did it twice in 20 miles.
What should I look for? Car is an '04 automatic.
tom...
Old Dec 19, 2009 | 12:06 AM
jrose7004's Avatar
jrose7004
Mine has done that about 3 times during the two and a half years that I've had it.
Old Dec 19, 2009 | 01:21 AM
Jnape's Avatar
Jnape
tom...
Active Handling activation will cut it off. Many things can cause an activation I.E road surface, new tires, alignment ect. Let alone a mechanical issue......
Old Dec 19, 2009 | 01:37 AM
oakvillec5's Avatar
oakvillec5
six speed here, never have had an issue with my cruise, in fact it really is quite nice. Hope you resolve your issue.
Old Dec 19, 2009 | 03:18 AM
white90conv's Avatar
white90conv
It is most likely the brake switch. either defective or misadjusted.
Old Dec 19, 2009 | 11:05 AM
Tom73's Avatar
Tom73
I was thinking that as the brakes wear, the pedel would get lower, and then could it activate the disconnect switch. Maybe I need a brake job to fix the cruise control?
tom...
Old Dec 19, 2009 | 11:31 AM
k0ts's Avatar
k0ts
tom...
The brakes are hydraulically adjusted so the peddle travel should stay the same.. Also, it's spring loaded to return to the stop...
Old Dec 19, 2009 | 12:29 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Have you pulled your codes yet to see if anything shows up there?
Old Dec 19, 2009 | 05:11 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The Active Handling system can activate for a number of reasons. Some justified and some NOT. DTC codes can also help point to the problem.
The next time it kicks out, look at the DIC and note the message. If it says Active Handling Active,,,thats an issue.
Normally, the switch on the Brake Peddle gets out of adjustment and gets too sensitive. Any little bump or vibrations can trip it and shut down active handling.
Old Dec 20, 2009 | 02:56 AM
Bluefire's Avatar
Bluefire
good advice.
I just wanted to add the reason my CC was kicking out. The Steering Wheel Position Sensor was going bad and would randomly trigger Active Handling events that disengaged the CC.
Good Luck in the hunt.
Old Dec 21, 2009 | 10:13 AM
Oldvetter's Avatar
Oldvetter
Originally Posted by Bluefire
good advice.
Even in a normally functioning C5, if you jerk the steering wheel the cruise control will go off.
Old Dec 21, 2009 | 10:32 AM
DeeGee's Avatar
DeeGee
Probably worth checking your codes as you may have an incipient active handling problem
Like Bluefire, I need a new SWPS fitting. My cruise control trips out when the AH has a glitch.
Old Aug 27, 2012 | 10:28 AM
Tech4882's Avatar
Tech4882
I was having the same cruise disengaging problem with my '01. Seemed very random - some days it would work fine. I checked all the grounds and sensor connections, SWPS, yaw, etc, nothing seemed to help. I was having a slow leak in my left rear tire - about 1 psi a day. I noticed that when the the pressure differential between the left front and left rear was more than 3 or 4 psi the cruise would disengage and also the left front brake would come on for a split second. Must be enough diameter change to trigger the AHS. I now check the tire pressures every day and keep them as close to 30 PSI cold as possible. Crusie is now working fine.
Old Aug 27, 2012 | 12:50 PM
cor66vette's Avatar
cor66vette
C3 of Year Finalist (stock) 2019
C2 of Year Finalist (stock) 2019
That was the case with a Lincoln Town Car I once had.
Old Aug 27, 2012 | 01:05 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
There are 2 ways that the ECM will release or unlock the converter
1st --and reported MISFIRE--whether real or fasle will unlock the TCC
2nd---Any tap on the brake pedal or short circuit on the brake switch will unlock the TCC
I've seen simply the floormats cause this before-
Many modded engines create false misfires--just the nature of the beast-the only way to eliminate the false misfires is to disable or desensitize them in your tune
Old Aug 28, 2012 | 06:00 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Check the PROPER operation of the BRAKE & CLUTCH micro switch adjustments!! If there wrong,, it will affect cruise control operation.. Both switches should be fully compressed and CLOSED for proper operation. When the brake or clutch is depressed, it should disengage cruise.
BC,
To Cruise Control
